Johor Bahru - share is caring - Part 2
  • Have you been Scammed?
  • Need someone to talk to?
Coffeelix
Anyone knows where in JB can buy this kind of simple chair?
I prefer the hard plastic type, nicer design also can, want to see what they have in the store. SG normal hardware shop range quite small.
TFValue Mart at Nusa Bestari and Bestmart also at Nusa Bestari
Coffeelix
Nowadays traffic coming from woodlands is always heavy …
is it the traffic pouring from jb added to the no?
Can’t imagine myself staying at woodlands. Will b so frustrating …
If customs is built bigger, will it get worst?
Andrew833
Outside Sutera Mall has a booth selling durians.
Damn expensive.
Kampung durian 3 for rm100.
Bought in Singapore 3 for $10.
Red prawn and msw iirc RM28 to rm38 per kg.
Surprisingly ytd Friday I went in at 11am out at 7pm no queue for CIQ.
Bought android TV box for RM370 at Ksl after discount. :o
That is a shop before demolish, is cheap and good. Now gone. Currently makeshift stall is very ex. Next time try Ah shui. Google for address.
Habrosus
Ya, I was thinking Ah Shui is like just round the corner so really wanna eat durian while at Sutera Mall should just Grab or drive over if time permits.
Coffeelix
Anyone heard of this ?
I m thinking to pay a visit as my arm seems to have sprained in my wrong sleeping posture
dao
Today...at North Side
7.47am - Bus dropped off at SG's CIQ
7.50am - Cleared SG's CIQ
8.02am - Cleared JB's E-Gate
Sitrep
• Manual Counters: < 10
• E-Gate: 👍👏
• MACSv02 applicants: not opened yet? Says 'Closed' on banner.
• 3.47 @ Sentral
From today onwards, don’t need to apply for MDAC/MACS. Don’t need to fill up the form too. Just use your passport for egate.
Andrew833
If you take CW bus, will pass by it. Can try press bell or take grab. Need to check season or not. Beside it, there is a nursery, can walk walk see see.
SongManKranji
High Honorary Member
Habrosus
Yes, saw it a few times, but not durian-desperate enough to make a stop. :s13:
Really ah, so never apply before also can use e-gate?
Don't forget to check the app to make sure your entry and exit are recorded, if you want to attempt.
hwsstx
Yes. Don’t need to apply. Just use your passport for the egate. Tested this morning.
Today manual counters are still in operations.
...once most of the manual counters replaced by E-Gate then will be official.
