Nintendo Switch thread - Part 3
Dorkable
Yeah must change both on website and "system" in switch right? Got to login again.
If there's a dedicated account for another country then no need to do that.
In my case, I usually only change the region on the website under my Nintendo account. I never had to make any change on my Switch console as it will auto detect the change done on the website.
LIN_JOEL
Hi, if my joy in cursor sometimes move by itself during games, is it faulty and possible To fix it?
bought the switch 6 to 9 mths ago but having this issue 2 to 3 mths after purchased.
Elysium87
google for "how to fix joy con drift" and in youtube as well
common problem
matchalatte23
Hey! I had the same issue with mine as well. Try checking if there’s any dirt buildup or grime underneath the thumb sticks. Or else there might be a hardware/ software issue.. is your switch still under warranty?
or else you can try get a new controller for that.. try this https://www.hardwarezone.com.sg/feature-best-game-controller-deals-singapore
LIN_JOEL
Warranty wise I’m not sure cos I seldom play it and the last time I played with it was a few months ago.
matchalatte23
ohhh... cause I also read somewhere that controller lags are pretty common for switch.. what I would do usually is to disconnect and re-connect my controller.. Maybe u can try this
Fixing Joy-Con Lag Problems
  1. Go to System Settings.
  2. Scroll down to Controllers and Sensors.
  3. Select Disconnect Controllers.
  4. Confirm your choice and wait until the message All controllers have been disconnected appears on the screen.
  5. You need to detach your controllers from the console.
LIN_JOEL
Mine is not lag, is auto move or a few seconds.
But will give it a try.
Thank you :)
Techno Pride
I'm thinking of getting a Nintendo Switch Lite for ~$220 brand new.
Not really into collecting physical cartridges. From Qisahn website, it looks like the console can be changed to America/USA. What's the Nintendo store like?
Is it like Steam, where there are frequent sales? I'm not really keen on getting new games for $60 a pop, more looking into older games for cheap.
crystalnox
Check out https://www.dekudeals.com/eshop-sales
Add to wish list and wait for a sale, although Nintendo first party games are rarely on sale. ie Pokemon, Mario
bladez87
now cant really find soft mod sets anymore
mocax
after buying nintendo switch few months ago, i've been only playing retro games or remastered retro games.... totally no interest in the modern games... is that normal? :frown:
networked
still waiting for "jet" and break dancing.
