your antivirus could be one of the possibility.Who can advise? my wifi dl speed only around 300Mbps when so near the router.
Using a TX-AX6000 router from China.
Why is it way too far from the advertised 2.5Gbps.
During installation, I saw that direct from ONT to Installer's phone can reach 2Gbps though.
300Mbps sounds like the limit of 1x1 802.11ac WiFi, try using other device with better WiFi like 2x2 MIMO. Typically laptops have 2x2 MIMO WiFi.Who can advise? my wifi dl speed only around 300Mbps when so near the router.
1. did u try direct connection and achieve reasonable speed?Who can advise? my wifi dl speed only around 300Mbps when so near the router.
Is your mbp capable of anything beyond 1GbE in the first place or are u using a Thunderbolt 10GbE dongleThanks for the replies.
My 16 Inch MacBook Pro 2019 can only get max 900+Mbps with wired directly from a 2.5Gbps router port. That's a far cry from the advertised number.
But wireless as mentioned only 200 - 300+Mbps.
Sounds like 1gbps ethernet and 2.4Ghz band Wifi.Thanks for the replies.
misleading especially to the non-tech-savvy peoplea lot of people are not aware that their current personal devices are 1gbps max.
So telcos offering 2.5gbps, 5 or 10gbps are misleading people to upgrade.
...Having a product like that is not misleading.a lot of people are not aware that their current personal devices are 1gbps max.
Marketing has always had that role to create a market when there is none. What's wrong siadubious marketing. even ai is old tech. you use gmaps is ai
Did they state the customers' equipment need to support this speed too? If not then it is misleading.Having a product like that is not misleading.
Better than term tpd insurance products sold with a misrep which u cannot test and see outcome
