POCO X6 series
kazuki666
Ask you all. How do I check confirm if my X6 Pro is 5G enabled??? Because Giga just announced free upgrade to 5G
froztheart
Go to Settings > SIM cards & mobile network > Select SIM card > Preferred Network Type, to check.
Enter " * # * # 86583 # * # * " in phone dialer to enable VOLTE setting.
3sniper
Is the X6 (not the Pro) able to connect to 5G or 4G networks for both SIM 1 SIM 2 simultaneously ? or 5G at SIM 1 but only 4G at SIM 2 and vice versa?
simon_84
Performance wise? Ok? For basic Netflix and MLBB
Should be okay since is a SD processor 7series.
MLBB can play on SD 6 series processor but using a 7 series processor is much better.
Not much difference compared to a 8 series processor.
kazuki666
Anyone here using Poco X6 Pro opt for physical 5G simcard and it works well?
3sniper
Bought 1 yesterday to replace family friend hp on demand by dad, shopee mall official poco.
X6, 8\256, white, $266, 12mth posb 0%
May I know what time you bought it and what discount vouchers were applied? Because I was there too at night but the white was unavailable and after applying discount vouchers was $279. Now without discount vouchers it's $309 in both shopee and lazada.
android
Wanted to get the X6 pro but saw the newly launched F6. How does X6 pro compared to F6 especially in terms of game performance and battery?
kazuki666
Based on Poco launch, F series are another league above X, followed by M series, and I think seem before C series .
I am replying from Poco X6 Pro now. Using it to play monster hunter now, rise of kingdom, battle bay. Social media apps all not a problem. So if you are a basic user, not fussy about photo quality, actually Poco X are good enough.
Used F1, X3 Pro, now X6 Pro
3sniper
Does your Poco X6 Pro connect to 5G networks for SIM 1 and SIM 2 simultaneously? Or SIM 1 to 5G and SIM 2 to 4G vice versa?
froztheart
6. Q: Does the POCO X6 Pro support Dual 5G standby (internet only)? Does the POCO X6 Pro support Dual 4G?
A: 1. Yes, the POCO X6 Pro supports Dual 5G standby (internet only) including both SA and NSA 5G, which ensures compatibility with a broader range of 5G networks;
2. Yes, the POCO X6 Pro supports Dual 4G.
https://www.mi.com/global/support/faq/details/KA-90062/
3sniper
Thanks. How about the Poco M6 Pro?
Also dual active internet? I.e cannot call/receive calls simultaneously?
froztheart
7. Q: What kind of network does POCO M6 Pro use?
A: The network standard used by POCO M6 Pro is GSM/WCDMA/LTE, and the network frequency is "GSM:2/3/5/8
WCDMA:1/2/4/5/6/8/19
LTE:1/2/3/4/5/7/8/12/13/17/18/19/20/26/28/38/40/41/66", which is provided by Movistar/ATT/Claro/Telcel /Vodacom/MTN and other operators support.
POCO M6 Pro supports SIM primary and secondary card differentiation, 4G+, 4G carrier aggregation, high-order modulation, VoLTE high-definition voice calls, radio and television network support, dual-SIM full Netcom and dual-SIM 4G.
The SIM card slot type of POCO M6 Pro is a three-select two card holder. The SIM card slot position is SIM1 on the inside and SIM2/TF on the outside
https://www.mi.com/global/support/faq/details/KA-90061/
piyozz
Does any user have heating issue? My daughter using it and feedback about heat issue. I bought fro.m shopee so can bring to Singapore service center?
8-lane
If u bought from the Poco official store on Shopee then yes...
