CPTMiller
- Nov 2, 2000
I believe Heya already have volte enabled.Hi all, I had just gotten a heya sim. Just to confirm VoLTe is not available yet right? Thanks.
Heya is typing...
They posted on Facebook something is Huat-ing. in response to eight, giga and Simba.
Same message was posted on their IG.
I hope is 5G, additional more data roaming
if 5G with the same price, y not?imo, 0 plus for moi with 5G. yes with moar data roaming, data, etc![]()
no la, just saying 5G doesnt add anything positive to moi usage. Thus in a way no use for moi.if 5G with the same price, y not?
True true.no la, just saying 5G doesnt add anything positive to moi usage. Thus in a way no use for moi.
current speed and coverage ish enough for moi.
5G is indeed fast, after using zym 5g for so many months. It really makes a difference, when loading websites, faster response, streaming videos don't lag.If heya offers 5G and roaming service to more countries, I will port back.
In ur observations, does it consume battery faster?5G is indeed fast, after using zym 5g for so many months. It really makes a difference, when loading websites, faster response, streaming videos don't lag.
nope. Based on my experience, phone uses more power when it's struggling to get a connection. In this case, it's places with weak 4G and network will drop to 3G vice versa. If the 5G network is strong, your phone do not require more power to stay on. Nowadays, phones are smart enough to conserve battery when your screen is off.In ur observations, does it consume battery faster?
Waiting to topup my planSame message was posted on their IG.
IMHO.5G is indeed fast, after using zym 5g for so many months. It really makes a difference, when loading websites, faster response, streaming videos don't lag.
After using 5G SA (M1) for a few months, I can tell you there is difference. Webpages and videos loaded instantly. Much faster than on home WiFi. You can see and feel the latency. Idk, maybe I'm more sensitive to the ms it takes from pressing to it load finish.IMHO.
There maybe will be a lot of folks telling you that 4G and 5G no noticeable difference.![]()
IMHO.After using 5G SA (M1) for a few months, I can tell you there is difference. Webpages and videos loaded instantly. Much faster than on home WiFi. You can see and feel the latency. Idk, maybe I'm more sensitive to the ms it takes from pressing to it load finish.
Simba 5g and zym 5g is like 一个天 一个地IMHO.
I also experience the difference. I just pointing out some folks think otherwise.
I also compare Simba 5G and Zym 5G - a lot of difference.![]()
IMHO.Simba 5g and zym 5g is like 一个天 一个地
Of cos is Zym kym. I got 1.1gbps on zym 5G NSA. Simba 5G I got 0.18gbpsIMHO.
Just say which one is sky.![]()
IMHO.In ur observations, does it consume battery faster?
