Head/earphones Recommendations Thread
gregory_choo
yea, since u are using portable dac, no purpose using bluetooth since the sound quality will drop. best is connect wired to the dac then to your phone.
if the phone and dac connects using lossless codec, then no drop in sound quality.
potato13
This is something i wanna learn..
As i usually stream my music from spotify. I only see the setting as audio quality medium, high, very high.
i guess these are not anywhere near lossless codec? i cant see their format. unsure if its mp3 or flac.
How / where can i get lossless codec music?
gregory_choo
spotify is not using lossless codec. normally use aac or ogg at 96kbps to 320 kbps.
tidal has option for lossless streaming.
gregory_choo
Thanks for the intro.. Hmm.. free 1st month.. I go test it out.. Tonite go download and try.. haha
not many people can tell difference between aac 320 kbps and lossless audio. if you are already paying for spotify premium, and
if you are one of them, then can save money.
potato13
ya.. already with spotify family for few years..
since 1st month free for Tidal.. will try and test test..
Test my ear can feel the different.
Also if my equipment can feel the impact..
I read if your DAC/AMP / headphone not power enough also no use..
r3f3r3e
Apple Music also loseless can try also. But i don’t really like because they translate Chinese song title to english. Sure blur 1
As for the lossy and loseless, very hard to say. If ur lossy music is 320kb type, then hard to differentiate unless u using good dac and headphone. Dun think u also go listen to the songs 5 times lossy and 5 times lossless to compare also lol.
But of course if u want a difference, have one. The cost difference also big difference lol
potato13
Not a fan of apple.. i dont use apple product.. Thus..
haha.. ya.. most impt ownself song.
Price for spotify vs Tidal..
Spotify family = $17.98
Tidal family = $16.98
Cost wise, i think Tidal cheaper?
r3f3r3e
Oh, i never tried the others cuz i subscribe to apple music. Cheaper to subscribe from singtel instead of apple music itself.
You can try apple music anyway cuz got free trial also haha.
potato13
Haha.. Tidal also got free trial.. I downloaded and testing now.
i think if Tidal work for me, i just stick to it. Its a pain to create playlist and slowly find and add back the song into the list..
My spotify have 15 play list i created..
Now doing slowly for Tidal..
If i wanna test apple music again.. need go tru this **** again.. whahhahhaa..
ZesiMuerte
I am trying to do some research to a new iem setup. Would like to hear some feedback from you guys.
Currently using my Westone W20 with UTWS5 or if I am home I use BTR5.
I am not exactly looking for an upgrade, more like something to maintain my current setup.
My budget:
Max:
Moondrop Variations
Westone Pro X30
Mid:
Moondrop KATO
Westone Pro X10
Low:
Moondrop Aria SE
Moondrop Aria 2
Audio Technica E40
I am also looking at Moondrop EVO because I find it aesthetically more pretty than UTWS5. Searching around reddit, there are mixed feedback. Want to hear what you guys have to say.
Lastly, any difference between BTR5 vs BTR15, the newer version? Thanks guys.
caterham7
My budget:
Max:
Moondrop Variations
Westone Pro X30
Mid:
Moondrop KATO
Westone Pro X10
Low:
Moondrop Aria SE
Moondrop Aria 2
Audio Technica E40
recommend to demo at headphone store
reason being, we have different shape ears, for IEM, getting the right seal makes all the difference
personally have bought expensive TWS, but ended up not using, due to the shell/case being too big for my ears
btw, which version of the UTWS5 are you using, mmcx or 0.78mm 2-pin? that will help limit your choices accordingly
r3f3r3e
does tidal have large varieties of chinese and jap songs as well?
potato13
So far.. All the chinese song i want can be found.. (Mainly 80s-00s Song for me... I uncle)
Just that some of the songs title are direct translated to English.. So its a bit of a pain to search in chinese words.
Jap sorry.. haha.. i dont listen to jap..
ZesiMuerte
MMCX because my W20 is MMCX connection.
Yea probably need find a day go down and try. I also found another one that people liked, Truthear Zero I think.
There is this shop by crinacle. That shop can test iem? I havr always only gone to Stereo.
caterham7
not sure, haven't visited headphone shop in years
last time, the shops that had testing
- Jaben
- Zeppelin
- Stereo
lazy now, use TWS during commute. if really want to block out noise, then i use etymotic er2se
ZesiMuerte
- Jaben
- Zeppelin
- Stereo
I know the convenience of TWS.
I haven't tried a TWS that sounded close to my W20 at all. Or perhaps I am just too used to W20 signature.
My space travel is around for abuse and convenience while my W20 is for enjoying music.
r3f3r3e
ya we same era except that I got listen to Jap songs as well. Ya really pain in the ass
expiredate
Hi all i wan to try headphones. Is there any headphones under 60 or 70.. Commute on train. Bluettoth connect to hp watch drama and listen spotify.. Best if got noise cancellation.
