zheng
- Dec 20, 2001
still got no public release of SD3... think sai going bankrupt liao
I haven't tried PixArt yet. It uses T5 encodings instead of Clip.
haiz comfyuiHmm... Nerdy Rodent says he could use it within 6gb vram.
Unlikely he loaded the 2K model as the model was released a few days later after his video was uploaded.
Depends on what type of ghost or demons.What base model is good for generating horror themed images like ghost or demons?
china chinese - guofeng.... ronghua.... only know this two popular one...what checkpoints are good for chinese models?
ok. civitai.guofeng.... ronghua.... only know this two popular one... there are many more can search for it
the relight look kinda unnaturalInstance Diffusion with ComfyUI support.
This allows for more precise control to image generation by breaking up the image into smaller chunks.
The example videos showed movement for a crowd of entities.
Next, tried IC-light HF just now.
The HF site is easier to use and I got better results, because the ComfyUI examples are not the same as the online demo.
Very useful in getting different backgrounds and directional relighting.
Below is the last keyframe of an existing animation generated using DynamiCrafter. So the hands degraded.
Speaking of which, the DC wrapper by Kijai now has ToonCrafter support as well.
new software again?It turns out that I can generate PixArt-Sigma images after all!
But the T5 encoder is very slow, especially if the prompt gets changed.
So it should only be used when the prompts are finalised.
The wide angle shot now works because the Abominable Spaghetti workflow is specially made unlike the online demo, and uses the Photon (SD1.5) model as the refiner.
It is ComfyUI, quite complex for beginners.new software again?
wao, i so outdated liao. what is good to use now?
installing the app look complicated...
