Wstc333
- Jul 1, 2022
Run whereOh no
Cham liao
Tio exposed liao!
run awayyyyyyyy!![]()
Run whereOh no
Cham liao
Tio exposed liao!
Run to Funan.Run where
How u know![]()
In before stalkOh no
Cham liao
Tio exposed liao!
Find me if Chiu canOwnself sexposed ownself now. Trick qn
his name moi neh even watch his beedios before also noe lo… in edmw sho famous
V difficult mehFind me if Chiu can![]()
Yalor how come i nvr see beforeMust be some secret threads
Means he wants to be found by u
your interpretation is totally wrong lor.Means he wants to be found by u
i think this has been covered before.If you are 2nd timer for BTO exercise, it states that 95% is allocated to first timer and 5% is allocated to second timer. But if the first timer application rate is < 1 which causes it to not reach 95%, do they just give the rest to all the second timers? or they just stop at 5% max for second timers and the rest just tell them no more quota for second timer?
Anyone knows the answer to this?
so they get chance as per queue number or after all the first timer has chosen?i think this has been covered before.
But here's it again.
The rest that's not allocated to 1st timers will be given to 2nd timers, making the pool of 2nd timers extending beyond the 5 percent of flat supply.
Means, more chances for 2nd timers.
they won't stop at 5% max and leave it for SBF. Won't one.
when the ratio is < 1. means all of the first timer gets it.so they get chance as per queue number or after all the first timer has chosen?
yesh de mm.so SBF cases means usually is half way through someone break up or smth along those lines right?
ooooo so everyone within the pool will get to choose?when the ratio is < 1. means all of the first timer gets it.
BUT, they don't really get to choose first.
They'll extend the quota of 2nd timer pool, pick the lucky 2nd timers, and add in back the first timer pool, then the final ballot number is produced.
