- Sep 16, 2018
How are you? I recently applied for a Singtel 5gbps package. Which one has a better signal transmission rate, HB810 or BE805? Because I don't have enough budget, I can only buy it from carousel. The second-hand HB810 was used for 2 months and cost $360. The new BE805 cost $300. My family doesn't play large games, but just watch movies and do basic online uploads. Could you give me some advice? Thank you.
Unlikely you will get a good answer for this question since basically very few people will get both of them and compare.
You may want to post your floor plan (with details like LAN ports location and intended placement location of the wireless routers) and see if it is possible to place the router in a central location to cover the flat.
Do you have any 10Gbps capable device (very few 5Gbps devices out there)?
BTW, if I am forced to select between Singtel issued HB810 vs TP-Link Archer BE805, I will choose to go with Archer BE805 as it is not locked to Singtel.
