doogyhatts
- Feb 13, 2018
which app?installing the app look complicated...
I used StabilityMatrix to install ComfyUI, Forge and Fooocus.
install stable diffusion is already look complicate.which app?
use ms bing/copilot image creator loh very easy to useinstall stable diffusion is already look complicate.
Hmm... then I think you better stick with Dalle3. Just use the Bing image creator.install stable diffusion is already look complicate.
Another option is to rent a GPU that has 24gb vram on Vast.ai.i try comfyui on my potato PC (without GPU).
took about 10 seconds per iteration
last nite, try out animatediff sample with many unknown feature names, took forever and i stop it.
feel my potato cpu going to boil at 100 C.
difficult without nvidia GPU, and my current desktop, i didn't cater for inserting discrete GPU.
i just trying out, and want to try to make short videos for youtube side hustle.Another option is to rent a GPU that has 24gb vram on Vast.ai.
For unverified machines, there are those single RTX3090 going from $0.13 to $0.18 usd per hour.
But doing the installation every time is the problem, just do minimal required installation will do.
For my local machine, 8gb vram is enough. When I need a much better system, I would just rent it instead.
RTX3060 Ti 8gb.i just trying out, and want to try to make short videos for youtube side hustle.
what is ur GPU ?
expensive stuffRTX3060 Ti 8gb.
sad.. forge is good..Forge to be converted into experimental mode.
https://github.com/lllyasviel/stable-diffusion-webui-forge/discussions/801
lol i want to make AI music video...Forge to be converted into experimental mode.
my first AI music. LOL...
wrote the lyrics myself...
please like and support.
