POCO X6 series
obgood
x6 pro 8/256 , lazada ... 303.58 after vouchers ......... 12/512 is 355.18
because of the platform voucher 14% off cap 60
*so far 35 sold by 8:38pm
103 sold by 11:35pm
normal x6 is 234.78 for 8/256
I think I missed this :frown:
pohu
I am currently using "POCO X3 NFC" model and wonder an upgrade to POCO X6 is a wise move?
Basically I need my phone for the following purposes on top of the call/text functions.
  • to manage my social media platforms
  • to draft my blog posts using "notes" of Xiaomi Cloud
  • camera capable of taking good photos and video (selfie or normal shot) with 1080p
  • using apps like Canva, etc.
  • must have big storage (I find that my WhatsApp eats a lot of space which I can't delete due to important data)
  • decent processor speed (like mentioned, I find that when I want to view a picture on my POCO X3 NFC, the loading of the picture is snail speed after upgrading the phone O/S)
  • Long battery life
  • I am not a game person
One of the things that attracts me about POCO X6 is the (12GB RAM +512GB) space specs
kazuki666
Stupid qns. Those of u using X6 Pro. Since it's only 1 simcard tray, how u all manage when traveling overseas where u buy local simcard?
pohu
The sim card tray should allow 2 sim cards to be able to fit in side by side, based on what screenshot.
HoGnix
It can hold two SIM Cards. For some old Xiaomi phone, its one SIM slot is hybrid, can put HUAWEI memory card. Not sure weather this X6pro SIM slot has one Hybrid capability or not.
Krabs.
the newer x and f series i think no more microSD function , force heavy usage people to buy higher 512 or 1tb which is fixed into the phone instead of card transferable to new phone
sim tray have top and bottom sides to put 2 card , slowly push the sim tray back while supporting it with fingernail against gravity
kazuki666
Pardon my noob. I didn't know simcard tray now is top bottom design.
Thanks!
Sausage
So far I see lowest price for X6 pro 8gb at $354, anyone found anything lower?
pohu
Usually you get your casing online or go to the retail stores to try and fit before buying?
Was looking around online and don't quite my liking especially read those comments which most complained the casing no align with camera lenses, etc.
pohu
Precisely, I am doing now. I b upgrade from 128 to 512
froztheart
Forcing is one factor, the other is to allow space to incorporate other components or reduce the width of the device.
Entire industry went this way for quite a while so its just a matter of time.
Sausage
Does anyone know why in lazada the screen shows lowest price after lazada voucher is applied is $354, then when you go to the checkout screen it says $379?
