TP-Link EB810v - Quick overview
JuveZzZ
Any benefits from getting it from starhub rather than outside model? I think there is no EB810v outside ?
HiHelloBye
take note that this is a service-provider model/unit. it's nowhere to be sold in retail (eg. Challenger store)
buying it from Starhub: Paying the Original price
buying it from Carousell: Cheaper than paying the Original price from Starhub
JuveZzZ
Is the starhub version locked ? Or can be used with any telco?
Locked to Starhub for firmware updates. Not recommended to be used with other ISPs. Same for HB810 (locked to Singtel for firmware updates).
TP-Link Archer BE805 is not locked to MR and it can be used with other ISPs.
kindredSG
Anyone managed to get EB810v into AP mode? When I select it, it pops up an error box - "Error code: 1 Internal Error."
JuveZzZ
Ok, in terms of performance will asus xt8 be better compared to EB810?
kindredSG
Fixed it myself somehow.. I think "restore" option (not factory restore - just what it got delivered as) may have done it as I could select AP Mode on the initial setup wizard.
Interestingly the EB810v SFP+ port did actually work, but would only negotiate at 1g with Ubiquiti DAC cable (UDM-Pro SFP+ DAC -> EB810v SFP+ DAC) - the EB810v port was actually working as a WAN port. Perhaps with a different module it could negotiate properly as there is no setting in the TP Link UI for it :(
I changed to using the SFP+ RJ45 module on the UDM-Pro and it was fine at 10g to the EB810v WAN RJ45. So now have it in AP Mode with an UDM-Pro in the middle, so it looks like this:
Code:
ONT 10GBASE-T -> UDM-Pro SFP+ 10GBASE-T WAN
                         SFP+ 10GBASE-T LAN -> EB810v 10GBASE-T WAN in AP Mode (using its 10GBASE-T LAN port for local server)
takeshi_lum
How do I set up WIFI mesh on EB810v? Possible to pair EB810v with other TP-Link routers?
I’ve tried pairing EB810v with AX53 but both of them can’t detect each other using WPS.
If set up WIFI mesh with EV810v, is it through the same way?
tzuthian1987
Hi guys, I just got my EB810v router, and subscribed to UltraSpeed 10Gbps from Starhub. I connected the router direct to Switch Hub 10/100/1000Mbps, before received by Macbook's hub. My download speed up 900-1000Mbps only.
How to achieve download speed close to 10Gbps? Sorry newbie here.
stephenbishop
You need to either connect your Macbook directly to the EB810v 10Gbps LAN port, or connect the EB810v 10Gbps LAN port to a 10Gbps switch which connects to your Macbook's 10Gbps port.
tzuthian1987
Thanks, I realized most switch hub is 10/100/1000Mbps. Anyone actually using 10,000Mbps switch?
Sammoking
Hi has anyone can share Aginet app nor the web management password for TP Link EB810V from Starhub for me to try. I triex Starhub@123, admin, Admin@1234, default SSId wifi password that starhub ask me try. All doesn't work.
Tp link ask me reset this router. Is it easy to reset and reseting? I wan access to change my wifi password only.
tzuthian1987
I had this issue last night, and eventually I just choose to reset it. Is quite straight forward, just hold the reset button until the router restart, then you set your new device password and done!
Pure 10G switch may be a bit more expensive. There are quite some cheaper 4/8 ports 2.5G switches with two SFP+ ports or one 10Gbe uplink interface. So they can be an option as well.
You may want to check out the 2.5G thread if you are interested in that option.
TP-Link EB810v has three 2.5G LAN ports. You can connect the 2.5G LAN port to pure 2.5G switch as well if you need more LAN ports.
1) Example connection for those who have two LAN ports on the living rooms, using low cost pure 2.5G switch
Starhub XGS-PON ONT in DB box -- patch panel -- living room LAN port 1 -- EB810v 10G WAN port
EB810v 10G LAN port -- 10G capable wired device in the living room (PC or NAS), optional
EB810v 2.5G LAN port -- 2.5G capable wired device in the living room
EB810v 2.5G LAN port -- living room LAN port 2 -- patch panel -- pure 2.5G switch in the DB box -- patch panel --Bedroom LAN ports x3 (each up to 2.5Gbps, total 2.5Gbps)
2) Example connection for those who have two LAN ports in the living rooms, using 2.5G switch with 10G uplink
EB810v 10G LAN port -- living room LAN port 2 -- patch panel -- 10G uplink of the 2.5G switch with 10G uplink in the DB box
2.5G ports of the switch with 10G uplink -- patch panel -- Bedroom LAN ports x 3 ( each up to 2.5Gbps, total up to 7.5Gbps)
stephenbishop
do you mind share which 10,000Mbps switch hub that you are using?
The cheapest 10G switch that I use is the 5 port unmanaged Trendnet TEG-S750 that I bought on Amazon SG for S$340. Plug and play and fanless. Works well and silent but runs hot as it is fanless.
1) You may go to the 10G/Homelab discussion and there are more options about pure 10G switches.
https://forums.hardwarezone.com.sg/...projects-include-10g-network-upgrade.6341518/
Example: post #140 of the thread.
From the following discussion, we can see that there are good switches to buy.
https://forums.hardwarezone.com.sg/...ubiquiti-vs-10gtek-simple-test.7036627/page-4
Some of the models mentioned.
1) MikroTik CRS310-8G+2S-IN
It has 8 x 2.5G Ethernet ports and 2 SFP+ ports, and runs RouterOS v7.
https://mikrotik.com/product/crs310_8g_2s_in#fndtn-specifications
2) MikroTik CRS309-1G-8S+IN
https://mikrotik.com/product/crs309_1g_8s_in#fndtn-specifications
3) Ubiquiti USW-Aggregation
https://dl.ubnt.com/ds/usw-aggregation-ds.pdf
4) TP-Link SX3008F, Omada compatible
https://www.tp-link.com/sg/business-networking/managed-switch/tl-sx3008f/
5) TP-Link ST-5008F V2
https://www.tp-link.com.cn/product_1649.html?source=list
2) More options for cheaper 2.5G swtches with or without 10G uplink
https://forums.hardwarezone.com.sg/threads/2-5-gbps-wired-home-network.6347648/page-14
kindredSG
Mine was Admin@7890 just in case we had same installer lol... but they seem to follow similar patterns.
