M1 Maxx (maxx.sg) Discussion
Jurong640
I just ported my line to M1 Maxx at retailer store this evening, porting haven't started yet, probably tomorrow.
The retailer told me say, actually GeeNet is faster than Maxx and Circles. I replied :cautious: isn't them all under M1? Same what. He says no, GeeNet faster. Ok then. haha
alvin1989
I only know geenet serves alot of those who stays in dormitories.
Jurong640
partly true, but now they have since quietly rolled out to the heartlands and serve the general public. Plans are mostly similar to what other mvnos are offering. they have rollover data, and data roaming too. But Maxx plans seems better on M1
Tedicious
Geenet $10 plan lose to majority of the other $10 plan out there
Tedicious
yeah. still not as competitive though. so far my Maxx temporary number, i find it to be responsive than my circles eh. Tonight will be ported in though
Oh really? In what way is it consider more responsive than circles?
I am thinking should I port my heya number over to maxx
tekster
Ok, thanks
So if you don't use for 270 days then get cancelled? Or if you don't buy an add on for 270 days then get cancelled
so $12 for first 30 days then u get 270 days free?
so total 300 days for $12. ok la v cheap liao
Tedicious
How does this works?
Buy the 1st $12 den no need to renew the plan?
What happened to all the data and talktime?
sango65
https://www.m1.com.sg/support/critical-information-summary
Service Plan Subscription Details
• Maxx Base Plan has no minimum commitment period and is auto renewed on a monthly basis, unless instructed otherwise by the customer. It consists of the following services
- Subscription Price: $5/month
- Promotional Discount: ^100% ($5)
- Local Data: 200MB
- Local Call: 10 mins Outgoing Calls & Free Incoming Calls
- Local SMS: 50 Outgoing SMS
- Free Caller Number Display until further notice
- Term: 1 Month
^Promotional Discount
Maxx Base Plan Promotional Discount
1. Base Plan @ $0 Promotion Discount will be valid till further notice. Refer to M1 website for latest update.
2. If customer register the Maxx SIM card and does not purchase any Maxx Plan Add-On by the following day, M1 may in its discretion terminate all services and customer’s SIM card.
3. If there is 90 consecutive days of non-usage of Key Services, (i) promotional discount will be revoked, (ii) customer will be charged for the base plan for the month; and (iii) Key Services will be suspended. For the purpose of Maxx SIM plan, “Key Services” refer to data, outgoing calls and/or outgoing SMS services provided to you.
-> Golden rule is before 90 days, to send 1 sms, make 1 call, or use data
Tedicious
- Local Data: 200MB
- Term: 1 Month
So technically still need to buy the $12 plan?
sango65
Still don't quite understand, isn't it supposed to be a monthly top up?
I just purchased m1 Maxx at $12 from a handphone shop. I will port in my Heya number to this m1 Maxx plan tonight.
The $12 100GB plan will expire after 1 month.
The base plan at $0 will reset every month. You need to maintain the base plan every 90 days to keep the mobile number. Otherwise, you need to pay penalty of $5 or risk the mobile number disappear.
So in essence, dont really need to top up after 1st month. Similar to Circles.Life $0 plan last time.
Tedicious
Thanks.
So technically still need to top up before after the expiry date? If nv top up after the expire date what will happen?
