looking for mouse recommendation
Phen8210
i find ergo of zowie ec mouse unbeatable
zowie ec is a common ergonomic mouse shape, i also used that
I also used these mice
g403/703
glorious model d
razer deathadder v3 pro
all the same shape
ferocity
For wireless mouse, might wanna consider getting those that run on AAA/AA batteries instead of built-in battery. My 15-16mth old logitech g pro superlight recently started encountering some weird standby drain issue. I have to manually turn off the mouse when i am not using it, if not the battery will drain like 40-50% within a few hours. Its possible to take apart the mouse and change the built-in battery but i neither have the tools nor think its worth the effort.
shadow84
Trying out the VXE R1 Pro Max, bought from Taobao and received it last week.
Bought a separate grip tape
Do u feel that battery draining is quite high? Im using the 3200 DPI + 4K dongle.
sp0inK
Not sure if this question may sound stupid, lets say I buy two exact wireless mice from whatever brand (logi, razer etc)
If i plug in the two 2.4ghz receivers into different devices (one one PC, one on laptop), can both mice be used independently and at the same time? Or will there be any interference or signal issue
liewhl
My office all use the same free gift dongle mouse in a small room, dun have interference.
elmariachi
how about corsair M75 Air ?
As long need to use Corsair Icue is red flag. There are many mice much better than that.
You might like the HELIOS II Pro S. Frankly, it's the best shape I've used so far. Basically a Zowie S2 shape perfected. 8k wired with 4k polling Dongle. Huano Pink dots blue shell.
Yongkit
many thanks for sharing.
as i normally only use the icue to update the mouse and kb firmware and both have build in device memory to store the setting.
after i update and setup i will uninstall the icue.
for the mouse itself i find it very responsive and on par with the rog Harpe Ace.
elmariachi
Harpe Ace is weird to flick the mouse. The back hump is much too intrusive. Even with the X2H, the hump doesn't sit too high that it interferes with flicking. To me the best balanced shape is still something close to the Zowie S2 shape. I haven't found any mouse that I felt more comfortable than that. That's why I'm still dailying my Helios II. It just fits the hand like a glove.
https://www.eloshapes.com/mouse/com...ce-vs.-Pulsar-X2H-vs.-Fantech-Helios-II-Pro-S
ferocity
why dont use Prime got $20 discount
$20 discount is what code or require which bank card? The only $20 discount I saw is a code that requires min. spend $80 I think. But anyway I already ordered so lazy to cancel and order again.
tigerwoods
Need to click the green redeem button
