GoldenStars
- Mar 14, 2017
I will suggest you contact Starhub to negotiate a better recontract price for your 1Gbps plan.
For cheaper plans like SIMBA 2.5Gbps (CGNAT without IPv4 add-on, not proven in terms of stability) and WC 2.5Gbps (ONR, aggregated 2.5Gbps, may have bad routing and not good for gaming) at S$21.80 per month, there will be compromises to make.
Noted. Thanks for your advice.
Pity they removed all the lower speed options
we only just signed last week and they haven't even came to do the fibre check.
