Revolut
Yiyong
Went to JBCC try one of the ATM see this eject card.... Went downstairs RHB smth one also mention got fee ..
Elon Jobs
Both Maybank and CIMB ATM no fee for me 2 weeks ago.
So you finally inserted your Revolut card the correct way into the ATM already?
WoShiPro
I rmb revolut use to issue Mastercard right now it's only visa. I got both version. Using master in Japan no fees. Using the visa card in Japan there fees so might be the same in Malaysia?
My Mastercard no fees in Maybank and rhb atm.
hisokaomi
How do all of you top up revolut (since topping up via debit/credit cards are chargeable)? Tried transfer from bank option and it leads to banking log in links for eGIRO arrangement.
sibeiTrolled
When i got my account, i setup the egiro and linked it with a account that has less than 500 SGD and left it like that ever since.
Account topup also via the egiro as i found it convenient.
hisokaomi
Account topup also via the egiro as i found it conconvenient
Is there any minimum limit to top up via egiro and does it allow top up only when needed? Sorry asking such as I'm planning to link it to a less than $1 account.. scared there could be bank charges if there's insufficient fund during auto top up.
Thanks in advance..
sibeiTrolled
Thanks in advance..
From what i am shown,
Min - $0.01
Max - My limit that i set during the initial egiro setup of 1K
So once the egiro is linked, when you need to top up, you just type in the amount and click on "Continue" and it will say something along the lines of "please wait for 24hs before your fund appears".
Realistically, it is quite fast and you shouldnt need 24hs as i just topup 0.01 and it appear instantly, maybe for larger sums?
For your case, just top up once you are sure the funds in the bank are sufficient? I have not tried having topping up more than what i have.
You should also look at revolut FAQ on this.
https://help.revolut.com/en-SG/help/app-features/linking-external-bank-accounts/
And also maybe drop a message to revolut to ask them about this so at least you have an official answer
natas
Just link it to your bank acct. Top up or withdraw when needed.
hisokaomi
Min - $0.01
Appreciate your detailed guidence, I'll try again. 🙏
Noted, will try🙏
I transfer from my bank account using FAST transfer as and when needed.
Noted, will try it.🙏
di3cbl
Thanks in advance..
If you are talking about topping up from the app, min is $20.
dreamycrunch
The "add money" to Revolut app has option like Googlepay and linked bank.
1) Are both topup via Googlepay and linked bank free?
2) I saw my local linked bank info has the BIC/SWIFT code in the detail, so Revolut top up via SWIFT and not FAST?
sibeiTrolled
Never tried gpay but likely it is through linked bank or paynow.
I am using linked bank since it is an eGiro which makes it easier to top-up the acount.
Should be free till the bank or mas mandates a charge? Not sure about this.
Same. I see my linked account has the BIC/SWIFT. Not sure tho.
nagase_4
Hi guys,
Now that JPY rates are good. I wondering can I top up SGD into my revolut and exchange it for JPY and hold the JPY inside?
But i'll still be using the card like when i go malaysia and top up SGD and it auto converts to MYR.
If like tat, will they touch the funds in JPY?
Thanks in advance!
yotoden
Hi guys,
Thanks in advance!
If you have enough SGD, it won’t touch your JPY.
dreamycrunch
How do I withdraw to my linked bank account for free?
FAQ seems to say by "Payment"->"+" -> "Bank Recipient" -> fill in bank detail information . However, I saw this entry field for "BIC/SWIFT" I hesitated. Will there be a Telegraphic transfer fee imposed then? Or is there any other shortcut for free withdrawal to linkedl bank?
In my case, should I input the SWIFT code for my linked POSB bank as DBSSSGSG?
y0ngc6
Yes, it's free actually and will show up as GIRO payment in your bank account.
