Mattress Recommendations
identity_1991
Any of you got mattress recommendations? Recently just bought a new mattress from shopee. But jin regret cos it’s too soft. I feel like i’m sinking. Need something more firm and sturdy to support my lower back.
zheng
maybe just one extra pillow will do to lift up your legs
m0n0n0ke
seahorse good enough
but then edmw standard ..no simmon no talk
identity_1991
I also looking for mattress, waiting for GSS.
any thoughts if foam or spring is better? I tried foam before. After two years it become too soft. Spring used long the spring will come out.
nachtsid.er
choose those with latex topping
bbfas here sweat alot, need something cooling
avoid the plush tops
vincsho
any thoughts if foam or spring is better? I tried foam before. After two years it become too soft. Spring used like the spring will come out.
I was using latex top and spring coil bottom. After a few years the latex sinking causing my back to hurt.. Tried a few mattresses in showrooms. I think king coil is not bad. For most hard mattress is seahorse but also not so comfortable because I am used to latex top.
identity_1991
I bot their firmest mattress and regret. Sometimes got back pain after sleeping.
King Koil is value for money. There are better mattresses out there but all very expensive.
That’s something I struggle with. Cannot too hard. Cannot too soft. Guess the only way is to go down to the showroom to try.
Dawgie_cool
Problem is the hardest seahorse is not hard at all...hence sometimes can give me bbfa back pain. I bot it bcos they can custom make the mattress to any size i want. I have a bed frame slightly bigger than super single, it's very hard to find the right mattress size for it. No choice lan lan have to live with the seahorse.
Try out the king koil at the shop if u like firm mattress. My mom using it and it's really comfortable. Four star is another contender if u look for budget firm mattress, but i still think can top up a bit and get the king koil, more bang for your bucks.
