Head/earphones Recommendations Thread
caterham7
Hi all i wan to try headphones. Is there any headphones under 60 or 70.. Commute on train. Bluettoth connect to hp watch drama and listen spotify.. Best if got noise cancellation.
yes
edifier W820NB+
creative zen hybrid
anker soundcore Q20i
haylou s35
soundpeats space
picun f6
can search for reviews on youtube
wait for cheaper price during next promo on aliexpress, lazada or shopee
Psycovirus
Hi,
Looking for a budget end game IEM, something from a Singaporean brand would be nice. I enjoy my Focal Radiance headphones and hope I can find something similar sounding. Thank you.
Your rig iBasso DX260
- What type of usage Music
- File format used in your source FLAC/Streaming
- Genre of music you listen to Rock, JPop, Jazz
- Headphone / earphone type UIEM
- Other requirements Full Tight Bass, Clean. 4.4mm Cable.
- Budget Up to $2000
Eien_kisu
pls recommend some earphones
- Your rig (mp3 players, amps, soundcard etc) -
bluetooth to phone and laptop
- What type of usage (movies/ gaming/ music etc)
listening to podcasts/people talking in videos and in meetings
- File format used in your source (i.e. flac, mp3 etc)
my downloaded podcast files seems to be opus, .ogg and .mp3
- Genre of music you listen to (classical, jazz, metal, etc)
- Headphone / earphone type (closed, open, cirumaural, IEM etc)
in-ear.
- Other requirements (if any) (mic, volume control, 5.1ch, 7.1ch etc)
mic and as many buttons as possible.
- Budget (in figures)
hopefully below $150, can can explode budget too. sick of cheap lousy earphones.
jokerpoker81
in-ear.
https://versus.com/en/wireless-earb...eling_mic=true&filter[]=multi_point_count=3,3
caterham7
Any good budget wired earphones with mic to recommend? <$100
Thanks!
if mic is priority [e.g. for Teams / Zoom], can consider apple earpods, below $30, there are 3 versions, 3.5mm, lightning, usb-c
if using in daily commute, suggest IEM, to block out noise, many china audio brands with affordable IEM from $10 onwards, look for those with removable cable, can choose cable with mic
one example is moondrop chu ii, below $30, but iirc, need to buy separate cable that has mic
potato13
moondrop chui ii + mic cable still below $100 buck. can go sim lim sq.. i think level 1.. there is a shop that you can test and try..
lustjoseph
I bought ka11 DAC to use with iem what iem recommended I am looking at simgot ea500lm,kefine delci and truthear zero red.....
twinbaby
I have recently lost one of my WMX4-1000 earbud from Sony. I like the feature because it has multi-point connections, it is mainly used for handling conference call and watching YouTube video on my smartphone it will be great if I can pair you with my TV as well. Also I would like a noise cancelling feature that is very good for the noisy office environment. I'm thinking of getting an open ear ear-phone at the moment. Alternatively is there any other recommendation? My budget is between $250 to $400?
MangoCAT
Recommend Xenns top for non-vocal + all rounder
Recommend mangird tea og 1 for female vocals ( chinese classic)
recommend az80 for male vocals dynamic preset for a bump to neutral range
