- Jul 5, 2001
I have been using theSo you really sold your p8p?![]()
P9P XL
What a coincidence! I've been using theI have been using thefor the last couple...P9P XL![]()
My previous experiences with Samsung phones were not so good. Mostly hardware and battery issuesThe middle is Samsung S24 ultra
Now we wait to unbox the P10P XLWhat a coincidence! I've been using the P9P (non-pro) for the last couple... too![]()
Battery life definitely better than pixel phones though.My previous experiences with Samsung phones were not so good. Mostly hardware and battery issues
Skip 8 & 9 and go directly to 10![]()
TL;DR
- Pixel users are experiencing an issue with the Spotify app that triggers a boot loop on playing a song.
- Users report being able to recover their devices by performing a force restart.
- The issue appears to affect Pixel 6, Pixel 7, and Pixel 8 series devices, and uninstalling the Spotify app seems to be the only viable fix.
Google’s upcoming Pixel 9 series might receive a lukewarm response, as users with older Pixel models are running into some serious issues in the days leading up to the launch. We recently highlighted an issue affecting Pixel 6 series devices that bricks some phones while performing a factory reset. Now, users with newer models are facing a similar problem when using the Spotify app.
User reports on the GooglePixel subreddit state that playing a song on Spotify triggers a boot loop on some Pixel 6, Pixel 7, and Pixel 8 series devices. Fortunately, unlike the factory reset issue affecting Pixel 6 devices, users are able to recover their devices by performing a force restart using the power and volume buttons.
Users say turning off notifications and clearing the cache for the Spotify app seems to resolve the issue. However, this does not work on all affected devices and, in some cases, it only provides momentary relief. Currently, uninstalling the Spotify app appears to be the only viable fix.
It’s difficult to ascertain the underlying cause at the moment, but it could be related to the Spotify app update that started rolling out to users on July 2. We’ve reached out to Spotify and Google, and we’ll let you know as soon as we have more details. In the meantime, we recommend uninstalling the Spotify app if you encounter this issue on your Pixel device.
What happened bro? Did a restart fix the problem?![]()
Didn't know about the infamous Pixel 8 green screen until today.![]()
Not my phone, saw a post on Reddit. Google images a lot of examples.What happened bro? Did a restart fix the problem?
Does it get resolved with a restart?Not my phone, saw a post on Reddit. Google images a lot of examples.
No le, need to send in for replacement, hearsay is static electricity and poor worksmanship, hope P8P no issue.Does it get resolved with a restart?
It's easy, get the OnePlus 12. there is no Pixel 8 PlusPixel 8 plus vs oneplus 12.
Which you all recommend?
if you can get the Oneplus 12 at $700 ish. then quite no brainer.Pixel 8 plus vs oneplus 12.
