Honor Magic V3
limmk
Honor sets Magic V3 launch for July 12​
// weibo
yhw22
Hopefully this round, the global will not need to wait for more than half a year to get it.
otts
Is China set magic OS? Does honor have any differentiation like vivo?
cos Vivo china set is origin OS while global is funtouch.
DeepseaG1523
China and Global is all Magic OS but China Magic OS 8 got more things VS Global Magic OS 8.
yhw22
Since dunno which model, have already.. i remember i read somewhere but i can't confirm since i dun use China set.
Yes. Now Honor China set also can install GMS, should be just an option to do so. But so far not sure CN set installed with GMS n global set GMS what are the different, or any limitation, such as Andriod Auto which most of the time not working. The rest google pay is working. Need those who using CN set installed with GMS to tell us more.
Gadgetfreakloh
Honor have a habit of releasing CN set without GMS. They will then let you register for the GMS later. This will take quite some time. Not sure if this new release is the same. So i will just wait until the global set is out.
yhw22
Yes, now it become self-service, you can enable it thru Settings.
yhw22
just for those for awareness:
you may jump to 6min 50 sec on how to enable google playstore from Settings. Note the video is in Cantonese.
yhw22
Finally found on enabling GMS from Honor China website:
https://www.honor.com/cn/support/content/zh-cn15855257/
部分机型升级至MagicOS 8.0支持谷歌框架,支持使用谷歌应用。
1、在荣耀应用市场搜索“谷歌商店”并下载安装。
2、使用谷歌服务需要打开Google Play服务开关,进入手机设置>>用户和账户,打开Google Play服务开关。
3、连接海外网络使用Google服务,中国大陆地区网络无法使用谷歌服务和应用。
4、具体机型请以产品实际升级版本为准,或咨询荣耀客服了解详情。
Some models have been upgraded to MagicOS 8.0 to support Google frameworks and the use of Google applications.
1. Search "Google Store" in the Honor App Store and download and install it.
2. To use Google services, you need to turn on the Google Play services switch, go to mobile phone settings >> Users and accounts, and turn on the Google Play services switch.
3. Connect to overseas networks and use Google services. Google services and applications cannot be used on networks in mainland China.
4. For specific models, please refer to the actual upgraded version of the product, or consult Honor customer service for details.
otts
ahhh means magic os8 have this built in liao. V3 should be same same w magic 6pro. cos previously os7 alot bros facing issues
yhw22
As far I knew, the only limitation on CN set is Auto Android but you get lot of additional features not in global, so give n take.
