- Jul 5, 2001
Most probably will just have to see how soon.. 1mth? 2mths? or 6 mths after china launch.Launch in SG?
China and Global is all Magic OS but China Magic OS 8 got more things VS Global Magic OS 8.Is China set magic OS? Does honor have any differentiation like vivo?
cos Vivo china set is origin OS while global is funtouch.
Since dunno which model, have already.. i remember i read somewhere but i can't confirm since i dun use China set.I see. But china magic os no google integration ya?
Yes. Now Honor China set also can install GMS, should be just an option to do so. But so far not sure CN set installed with GMS n global set GMS what are the different, or any limitation, such as Andriod Auto which most of the time not working. The rest google pay is working. Need those who using CN set installed with GMS to tell us more.Since dunno which model, have already.. i remember i read somewhere but i can't confirm since i dun use China set.
Honor have a habit of releasing CN set without GMS. They will then let you register for the GMS later. This will take quite some time. Not sure if this new release is the same. So i will just wait until the global set is out.Yes. Now Honor China set also can install GMS, should be just an option to do so. But so far not sure CN set installed with GMS n global set GMS what are the different, or any limitation, such as Andriod Auto which most of the time not working. The rest google pay is working. Need those who using CN set installed with GMS to tell us more.
Yes, now it become self-service, you can enable it thru Settings.Honor have a habit of releasing CN set without GMS. They will then let you register for the GMS later. This will take quite some time. Not sure if this new release is the same. So i will just wait until the global set is out.
