take note that this is a service-provider model/unit. it's nowhere to be sold in retail (eg. Challenger store)Any benefits from getting it from starhub rather than outside model? I think there is no EB810v outside ?
Is the starhub version locked ? Or can be used with any telco?
Fixed it myself somehow.. I think "restore" option (not factory restore - just what it got delivered as) may have done it as I could select AP Mode on the initial setup wizard.Anyone managed to get EB810v into AP mode? When I select it, it pops up an error box - "Error code: 1 Internal Error."
ONT 10GBASE-T -> UDM-Pro SFP+ 10GBASE-T WAN
SFP+ 10GBASE-T LAN -> EB810v 10GBASE-T WAN in AP Mode (using its 10GBASE-T LAN port for local server)
You need to either connect your Macbook directly to the EB810v 10Gbps LAN port, or connect the EB810v 10Gbps LAN port to a 10Gbps switch which connects to your Macbook's 10Gbps port.Hi guys, I just got my EB810v router, and subscribed to UltraSpeed 10Gbps from Starhub. I connected the router direct to Switch Hub 10/100/1000Mbps, before received by Macbook's hub. My download speed up 900-1000Mbps only.
How to achieve download speed close to 10Gbps? Sorry newbie here.
Thanks, I realized most switch hub is 10/100/1000Mbps. Anyone actually using 10,000Mbps switch?You need to either connect your Macbook directly to the EB810v 10Gbps LAN port, or connect the EB810v 10Gbps LAN port to a 10Gbps switch which connects to your Macbook's 10Gbps port.
Yes, I am.Anyone actually using 10,000Mbps switch?
do you mind share which 10,000Mbps switch hub that you are using?Yes, I am.
I had this issue last night, and eventually I just choose to reset it. Is quite straight forward, just hold the reset button until the router restart, then you set your new device password and done!Hi has anyone can share Aginet app nor the web management password for TP Link EB810V from Starhub for me to try. I triex Starhub@123, admin, Admin@1234, default SSId wifi password that starhub ask me try. All doesn't work.
Tp link ask me reset this router. Is it easy to reset and reseting? I wan access to change my wifi password only.
The cheapest 10G switch that I use is the 5 port unmanaged Trendnet TEG-S750 that I bought on Amazon SG for S$340. Plug and play and fanless. Works well and silent but runs hot as it is fanless.do you mind share which 10,000Mbps switch hub that you are using?
From the following discussion, we can see that there are good switches to buy.
https://forums.hardwarezone.com.sg/...ubiquiti-vs-10gtek-simple-test.7036627/page-4
Some of the models mentioned.
1) MikroTik CRS310-8G+2S-IN
It has 8 x 2.5G Ethernet ports and 2 SFP+ ports, and runs RouterOS v7.
https://mikrotik.com/product/crs310_8g_2s_in#fndtn-specifications
2) MikroTik CRS309-1G-8S+IN
https://mikrotik.com/product/crs309_1g_8s_in#fndtn-specifications
3) Ubiquiti USW-Aggregation
https://dl.ubnt.com/ds/usw-aggregation-ds.pdf
4) TP-Link SX3008F, Omada compatible
https://www.tp-link.com/sg/business-networking/managed-switch/tl-sx3008f/
5) TP-Link ST-5008F V2
https://www.tp-link.com.cn/product_1649.html?source=list
Mine was Admin@7890 just in case we had same installer lol... but they seem to follow similar patterns.Hi has anyone can share Aginet app nor the web management password for TP Link EB810V from Starhub for me to try. I triex Starhub@123, admin, Admin@1234, default SSId wifi password that starhub ask me try. All doesn't work.
