TP-Link EB810v - Quick overview
Sammoking
Mine was Admin@7890 just in case we had same installer lol... but they seem to follow similar patterns.
I think so. I tried and doesn’t work.
I asked Starhub to track their technician to get the password. I give them the technician ID which stated in work order but the hub trooper service and 1633 seem totally dunno how to contact their technician. They just push ard the issue.
I think i will try reset router .
Rzkr23
How do I set up WIFI mesh on EB810v? Possible to pair EB810v with other TP-Link routers?
I’ve tried pairing EB810v with AX53 but both of them can’t detect each other using WPS.
If set up WIFI mesh with EV810v, is it through the same way?
Were you able to figure out something?
I bought a RE705X extender and cant figure how to setup the Mesh.
Neither adding a mesh device from 810v portal by scanning nor WPS setup seems to work and slightly lost for ideas.
gld998
Q8. Can I configure the EasyMesh network with Tether Application?
A. Yes, currently some models have supported it, such as Archer C80, AX72, BE800, etc. If your main router shows EasyMesh on Tether App, you can add the satellite devices via App.
Please keep an eye on the official website and the router’s online updates for firmware updates when the new features are available.
https://www.tp-link.com/sg/support/faq/3529/
I dunno whether can work or not. I am about to upgrade to 5Gb and reuse my old router as AP - AX73.
mac34mac
Does anyone use the "Parental control" feature in this router? Can it be used to limit certain devices from accessing internet on certain time?
carey
Hi brothers,
I just bought EB810V from starhub shop at causeway point at $360
Can we just walk in and buy?
Currently, SH has a 5Gbps plan at $45/month with ONT but to get this router, it's $55/month for 24 months
While it's 'cheaper' since it's just $240 for the router, the plan may not go back to $45 once 24 months is up so we may end up paying extra $10 forever (until we recontract)
Lexng88
StarHub Shop allow us to buy, but need to warn you my S24 ultra wifi 7 when connected to EB810V. The router keep restart till today still no firmware update. BE85 have firmware updated to this issue
carey
Strange that a connected wifi device can restart the router o_O
It's okay, I don't have a Samsung phone and we use mainly iPhones at home
cscs3
Firmware for TP-Link router is never great. Worse is this is Starhub model. So you do not get firmware fix from TP-Link but push down from Starhub I think.
gld998
My side boh tai chee le.. could be just your router? S24 ultra x2 for me and wife plus s9 tab for my kid. Anyway the wifi 7 is not yet approved and still in dev. Band 6 is damn power. Download can see the difference one but coverage not so good. Waiting to starhub trooper to contact me for AP install
Apparatus
I don't have your issue when using my S24U with the eb810v
kimsix
Fellow eb810v users, please write to SH and Tplink to release updates. Tiagong they have beta given to users facing problems. Being over a month+++ still no official release
gld998
Reply to post #214.. when u use cat 6 instead cat 6a, of course u be getting 1gb instead of 10gb.
HiHelloBye
wah...
the smartphone got power to make the Wireless router restart by itself?:s31:
kimsix
wah...
ya if you read tplink forums, happened to be800 , same internals, something to do with mlo
Tplink already replaced their higher end be900 with v2, using broadcomm chipset, but still no mlo for their highest model lol
Looks like TP-Link Archer BE900 v1 is a complete failure so that they have moved to V2 using Broadcom chipset.
Some people in Reddit suspect Archer BE900 V1 has hardware bug.
Basically the general advice is not to buy the top end TP-Link consumer router (no matter it is Archer series or Deco series).
Actually Archer BE800 receives pretty decent reviews, along with the slightly lower end Archer BE805.
EB810v is pretty good in terms of HW spec, but unfortunately locked to Starhub and lose in terms of firmware features to Archer BE805.
