doki81
- Jun 11, 2010
10gbps switch quite ex..do you mind share which 10,000Mbps switch hub that you are using?
https://s.shopee.sg/6fMcquK68S
Ok thanks.I had this issue last night, and eventually I just choose to reset it. Is quite straight forward, just hold the reset button until the router restart, then you set your new device password and done!
I think so. I tried and doesn’t work.Mine was Admin@7890 just in case we had same installer lol... but they seem to follow similar patterns.
Were you able to figure out something?How do I set up WIFI mesh on EB810v? Possible to pair EB810v with other TP-Link routers?
I’ve tried pairing EB810v with AX53 but both of them can’t detect each other using WPS.
If set up WIFI mesh with EV810v, is it through the same way?
I bought a RE705X extender and cant figure how to setup the Mesh.
Neither adding a mesh device from 810v portal by scanning nor WPS setup seems to work and slightly lost for ideas.
Can we just walk in and buy?Hi brothers,
I just bought EB810V from starhub shop at causeway point at $360
Currently, SH has a 5Gbps plan at $45/month with ONT but to get this router, it's $55/month for 24 months
While it's 'cheaper' since it's just $240 for the router, the plan may not go back to $45 once 24 months is up so we may end up paying extra $10 forever (until we recontract)
Strange that a connected wifi device can restart the routerStarHub Shop allow us to buy, but need to warn you my S24 ultra wifi 7 when connected to EB810V. The router keep restart till today still no firmware update. BE85 have firmware updated to this issue
Firmware for TP-Link router is never great. Worse is this is Starhub model. So you do not get firmware fix from TP-Link but push down from Starhub I think.StarHub Shop allow us to buy, but need to warn you my S24 ultra wifi 7 when connected to EB810V. The router keep restart till today still no firmware update. BE85 have firmware updated to this issue
My side boh tai chee le.. could be just your router? S24 ultra x2 for me and wife plus s9 tab for my kid. Anyway the wifi 7 is not yet approved and still in dev. Band 6 is damn power. Download can see the difference one but coverage not so good. Waiting to starhub trooper to contact me for AP installStarHub Shop allow us to buy, but need to warn you my S24 ultra wifi 7 when connected to EB810V. The router keep restart till today still no firmware update. BE85 have firmware updated to this issue
Connect my second unit via Ethernet backhaul 10g port of first unit to 10g wan port of second unit . The connection only show 1G. Does anyone else face the same issue ? Backhaul cable is cat 6
Mine works fine
wah...StarHub Shop allow us to buy, but need to warn you my S24 ultra wifi 7 when connected to EB810V. The router keep restart till today still no firmware update. BE85 have firmware updated to this issue
bump bump bump!Fellow eb810v users, please write to SH and Tplink to release updates. Tiagong they have beta given to users facing problems. Being over a month+++ still no official release
wah...
the smartphone got power to make the Wireless router restart by itself?![]()
ya if you read tplink forums, happened to be800 , same internals, something to do with mlo
Tplink already replaced their higher end be900 with v2, using broadcomm chipset, but still no mlo for their highest model lol
