Fastest ISP?
seowbin
It looks like you are using ILC links for POP to POP connections? Are 8 submarine cable systems going to 8 different POP? Usually an ILC using the subsea cable is a combination of at least 2 cable systems if it is long distance. For instance if the POP is in USA the the ILC link use 1 subsea cable from Singapore to Japan (APG, AAG, SJC, ASE, C2C...etc) first then interconnect to another subsea cable from Japan to USA (PC1, Faster, NCP, Unity...etc), it rarely has 1 subsea cable system connect end to end between 2 POPs.
Mine never go US
So it's 1 iplc go directly to the POP. Got primary and secondary so 2 subsea per POP liao :s13:
cyberet
hmm... VQ got improvements :unsure:
VQVQ OldMR BizMR Biz Old
area区域averageaverageaverage平均
Whole network全网182.5ms207.3ms149.1ms143.3ms
move移动103.0ms108.3ms81.0ms76.5ms
China Unicom联通248.0ms373.1ms81.3ms73.2ms
telecommunications电信201.0ms279.7ms87.7ms82.8ms
South China华南202.7ms297.9ms53.8ms50.0ms
North China华北188.1ms276.6ms79.6ms78.8ms
East China华东196.7ms263.3ms81.6ms78.6ms
Central China华中206.7ms301.8ms77.3ms74.3ms
northeast东北254.0ms284.2ms144.5ms104.0ms
northwest西北227.7ms336.6ms103.9ms99.9ms
southwest西南186.8ms295.0ms88.7ms76.7ms
Hong Kong, Macao and Taiwan港澳台79.4ms61.5ms53.3ms49.1ms
Asia亚洲94.4ms105.0ms62.0ms64.5ms
Europe欧洲191.5ms205.5ms188.5ms182.5ms
Africa非洲287.9ms291.1ms281.6ms246.9ms
North America北美洲215.1ms219.3ms225.9ms216.4ms
South America南美洲330.8ms345.3ms365.4ms338.5ms
Oceania大洋洲101.3ms100.8ms95.0ms99.6ms
emilex
May I know your VQ is the standard plan or raptor gamer? CGNAT or public IP?
Henry Ng
Got this from ChatGPT 3.5
in the real world, what are the websites that support 3 gbps download speed
As of my last update in January 2022, websites that support 3Gbps download speeds for individual users are quite rare in the consumer realm. Achieving such high speeds typically requires specialized network infrastructure and is more commonly found in enterprise environments, data centers, or research institutions rather than on public websites accessible to individual users.
That being said, some services may be capable of providing faster download speeds under optimal conditions, particularly those that utilize advanced content delivery networks (CDNs) or host their content on high-performance servers. However, consistently reaching 3Gbps download speeds would be uncommon for most users due to factors such as internet service provider limitations, network congestion, and the capabilities of users' devices and home networks.
In practical terms, websites that offer large file downloads, such as cloud storage services, software distribution platforms, or multimedia streaming services, may be better equipped to handle faster download speeds. Additionally, websites that cater to professional or academic users who require high-speed data transfers, such as research databases or scientific computing platforms, may also support faster download speeds.
Overall, while the internet infrastructure continues to evolve and improve, reaching and sustaining 3Gbps download speeds on a regular basis remains a significant technical challenge for most consumer-grade websites.
AvatarViper
Moi used excel feature and color scales to make it more colourful
Included moi network to pit against the big boys as well :s13:
I removed MR biz since here mostly consumer ( i suspect biz and gamer is the same routing anyway)
which website do you go to test?
@Mach3.2 will like this test very much.
Your VQ results are quite decent.
Singtel is so so so bad with this test. You can see my test results below, using WiFi (but WiFi should not be the real issue here -- got good connection using RT-AX86U router at 3m distance only.
https://www.meter.net/tools/world-ping-test/#0-35860-9cfdc6
@ksw2010
Just wondering if you can give this test a try from your side.
Now I can not easily test with different IPv4 address segment any more -- using Singtel ZTE F8648P ONR now with the newly installed Singtel 5Gbps plan.
Mach3.2
Just looking at the red coloured cells: at least M1 is much better than Singtel. VQ is the best so far.
VQ > M1 > Singtel (not counting the MR Business plan).
m1 hit and miss into Europe. kinda weird considering M1 have Arelion IP transit.. :s13:
VQ is a peering **** so maybe that's why they are doing a bit better there.
LiLAsN
For me, I use the R3 router to block overseas game servers including HK, Korea, Japan and Australia.
The intention is connect to the fastest server which for the games that I play, are Singapore servers. So am aiming for low latency to Singapore game servers.
Nevertheless, am impressed to see MR Gamer package. For games that only have overseas servers, I suppose having low latency there will help greatly. Thanks for sharing.
VQ 3Gbps Latency Score - https://www.meter.net/tools/world-ping-test/#0-36591-c01712
