Philips TV Discusion Thread
R6exR6
My Philips 65" PUT6023S/98 TV has died. Only 3.5 years of service and 6 months after warranty expired. Accumulated only about 10,000 hours of usage.
TERRIBLE !!! 😤
My previous Samsung lasted 13 years! 💪
Not gonna buy Philips again. 😪
sgmem88
TERRIBLE !!! 😤
wat happen?
if power or pcb issue mayb can repair/replace
R6exR6
wat happen?
No idea. Just when power ON, screen blink briefly with Philips logo, then Nothing. In short, the only thing I can do is power ON and OFF ... nothing else.
sgmem88
seem common issue
happened to my last LG, got someone to replace the mainboard and work for 1plus yr then same issue again. initially want to diy as found the mainboard in TB and is quite cheap but wifey want new tv so got hisense instead :s13:
Henry Ng
seem common issue
Hisense TV do not have Starhub TV+ app so it may not be convenient to watch Starhub TV on this TV directly. It will be better to go for TV with the Starhub TV+ app if using Starhub TV. This is helpful for bedroom TV that we do not want to rent an extra box.
sgmem88
good to know
but i using singtel tv and for living rm
ragnarok95
Senior Moderator
Senior Moderator
Viewed PUT8808 and is blown away by its details and almost OLed- like
I bought the 50PUT8808 and the TV was delivered yesterday. For S$849, i think this is one of the better 50in 4K TV out there in term of display and sound under S$900. One can also consider Philips 8100 which is Qled but no ambilight and weaker sound output.
Actually quite impress with the TV speaker. 4x10W total 40W. Yesterday load up netflix with dolby vision and atmos since this TV can support both, was a bit blown away by the sound. I don't even need a sound bar.
Sambuca78
Is this matte or gloss screen? Thks
R6exR6
I thought blooming only on mini-LED
mini-LED would have less blooming compared to normal LED. Anyway, need full-array local dimming with many zones to counter blooming, aka the halo glow on dark background surrounding bright, especially white objects
ericwilis
how is this so far ?
saw the same exact model today and was quite impressed
but im worried if the ambilight might cause more eye fatigue
Bumblebee Man
SG is always late with the Philips new oled models. And the best Philips TV series is always not brought in to sg too
ragnarok95
Senior Moderator
Senior Moderator
Ambilight is good cos you can actually set so it won't be too extreme. I set it on since i bought this in Jan. So far TV working okie. Sound is good.
petetherock
Moderator
Moderator
Ambient light is meant to decrease fatigue and improve contrast
Good feature to have or add a light strip behind your tv
