buffybuffy
- Oct 15, 2007
Care to share some tips?
Whatever shown on CNA not really applicable to local arcade. Don’t know about other claw machine shops as I only play in timezone.
Try this BCA Academy course. Think can use skillsfuture.Care to share some tips?
They set the value as well. Meaning it must hit the preset value then the claw will give that 100% grip.Many of the claw machines are programmed to have a proper grip for only a split second. But once in a while can be programmed to let u win, that statistics adjusted. Abit like the slot machine.
After all you have to pay for the rental and the profits.
That’s more like diggingTry this BCA Academy course. Think can use skillsfuture.
https://www.bcaa.edu.sg/docs/librariesprovider2/courses/certification-courses-for-tradesmen/44018_210622_0022-(hydraulic-excavator-operation).pdf?sfvrsn=873bfb07_0#:~:text=Participants have to attend at,Completion in Hydraulic Excavator Operation.
Those the soft toys are really like stack until like a mountain full. So easily can just “scope” one down.I see some MG PG they go pasar malam and take trolley, go around machines and grab a lot..
Dunno how they did it or they know the trick to catch.
only tip is don;t play.
the claws are purposely made so weak.
u don't play, u already a winner
The spatial senses you need are similar tho. Gauging position of the claw vs the target.That’s more like digging
I saw many father catching for their daughters or wife. Also seen sons crying for their father or mother to catch.cannot la, go paktor can bring zharbor go catch
The claw grip got many pattern one. Not enough grip or some spin as it lower. So still quite differentThe spatial senses you need are similar tho. Gauging position of the claw vs the target.
