- Mar 22, 2011
they have 1.5 weeks to go.So far only zym (Singtel MVNO) have VOLTE. But face many issues in the first few days, so maybe other Singtel MVNO are holding back the upgrade
Already left less than 12 days liao still no implement. Later got teething problem.So far only zym (Singtel MVNO) have VOLTE. But face many issues in the first few days, so maybe other Singtel MVNO are holding back the upgrade
so far i think vivifi and gomo are the few singtel mnvo with esim support, not sure about the rest of them and i know zym no mentioning of it.zero1 don't have esim yet right ? Has the volte been implemented?
most likely mobile 3G will be shut down on after 31 July. Only those POS machines, paywave NETs machine which are majority on 3G, will remain on 3G for awhile before the transition. i still see quite alot 3G connection. That is the reason why sometimes when we paywave, it took so longI will not be surprised when 3G is still running after July. VoLTE is just a call feature yet some telcos made it like some premium function and kept it out of MNVOs.
Generally the speed is worse when you use mobile data as a hotspot in a Mi-Fi router and ping is much higher as well compared to fibre broadband. All these can be felt as lag in real world performance. During peak hour, mobile data speeds is also significantly throttled thus making the experience even worse as everything will load super slowly. You can simply try for a few days/weeks using hotspot data from your phone for all your home internet needs and see if it's bearable to you.Fellows, I have a qn:
say I dun play games (dun need low latency) and my use case is remote meeting, normal netsurfing, netflix streaming no torrenting, what's stopping me from getting a MVNO such as Zero1 and putting it into a LTE router and replacing my ISP BB, with a "telco" MVNO?
nothing stopping youJust try it out and see if performance is acceptable .
i did that for a few months during covid when the telcos could not install fibre at my new place (moved in just before lock down).
At that time, was on TPG free trial. used an old android phone (Redmi Note 2) for USB tethering to my router, to replace the WAN connection. Hence, no change to internal LAN setup. No complaints from the rest of the family.
not the fastest speeds, but no torrenting, just streaming, casual internet use, and zoom meetings, online classes.
Any traffic shaping even for your "normal" casual internet use? I wonder if they (MVNO/even the big 4) detect the usage pattern like a home BB, they will throttle until insane?
Year ago i went korea,bought thing using my cc. The network is so fast just tap and the receipt is like instant print outmost likely mobile 3G will be shut down on after 31 July. Only those POS machines, paywave NETs machine which are majority on 3G, will remain on 3G for awhile before the transition. i still see quite alot 3G connection. That is the reason why sometimes when we paywave, it took so long
3G shutdown for SingTel network has been delayed to November so probably VoLTE implementation also delayed.1 aug liao but my phone nv show volte
Ok 3 month to go lol den delaya again3G shutdown for SingTel network has been delayed to November so probably VoLTE implementation also delayed.
