Any Claw Machine Expert Here?
Computeron
Today’s catch.
in life, there is always at least 2 views from ppl.
1 is ur view, which u think is jin saki/pro
2nd view from other ppl, waste money sia.
ask_yip
I always get scolded by wife for playing claw machine lol
my technique are:
look for toy that is not stuck with other toys that sit near to the lobang
try 1 coin and see the grip strength
if strength is ok then continue trying
will stop if cannot get in 4 coins
buffybuffy
my technique are:
Same here but just that i don’t test grip. I only use dragging method. Drag is down
Last time I work in a place where we lease to claw machine.
The secret told to me by the machine vendor is ...
I can't tell cos it's top secret ..
def binary_search(arr, value, offset=0)
mid = (arr.length) / 2
if value < arr[mid] binary_search(arr[0...mid], value, offset) elsif value > arr[mid]
binary_search(arr[(mid + 1)..-1], value, offset + mid + 1)
else
return offset + mid
end
end
Kiwi8
Deluxe Member
There is this Korea expert featured on their talent show really very good one.
I think the show name is Life Experts aka Sheng Huo Da Ren on channel u.
That claw machine expert is really expert.
gungho
I always tell myself the money spend on claw machine can buy a soft toy
madcampus
Just go youtube research how claw machine works. The grip will be tight after certain numbers of tries. It also highly depends on positioning of the toy - usually near the chute higher chance may fall thru after the grip opens up midway.
