Hisense TV
Which Model(s) are you interested in?
  • U6H (4K, 60hz)
    Votes: 13 8.7%
  • U7H (4K, 120hz, Full Array Local Dimming, HDMI 2.1, VRR)
    Votes: 50 33.3%
  • U8H (4K, 120hz, Mini LED, HDMI 2.1, VRR)
    Votes: 86 57.3%
  • U9H (4K, 120hz, Mini LED, HDMI 2.1, VRR)
    Votes: 36 24.0%
  • Total voters
    150
raintr33
can use mewatch on mobile/tablet screen share/cast to tv
I am getting disappointed with the limitations of Vidaa after using it for 2 months, their Vidaa apps like iQiyi and WeTV is quite buggy and comes with limited features compared to the web or Android apps. Good thing is the processor is fast and can run the apps fast. Youtube apps also jin irritating with the constant adverts...
I am considering to get a Google Chromecast 4K and forget about Vidaa... still trying to convince myself to spend the $70 or live with it since its still usable just not ideal...
Also Google is going to stop the Chromecast product and coming out with new Google TV Streamer which is rumoured to cost twice as much. If Chromecast price drop after the TV Streamer launch, will be even easier to decide then.
sgmem88
if u need 4K then chromecast is good, mayb get used one if dun mind
else web and screen share/cast are not bad options
oh ya kids alway press ok button for adv in yt :s13:
raintr33
I tried but Carousel don't have any listing for a used 4K.
Would you know if there is any difference between the 4K and Chromecast HD ?
sgmem88
nvr use both
from spec seem only diff is 4K vs HD
your streaming apps/accts have 4K ?
JLowX13
Hi, just bought a tv and was delivered. for channel U, the drama is playing in korean language. how do i switched it back to chinese (dual sound drama) thank you
sgmem88
which model you got?
mine just need press 'options' button on top right corner to select audio/subtitle language
JLowX13
wonder you found out the way?
tried last night can change audio option by pressing ’日‘ button on left side, middle of hisense remote
Hi, i change at the audio language, but had to do it everyday whenever the korean drama. my mum had given up. not check on it recently. did not recall a button at the side. will explore.. thank you! :)
ohmyn3oooo
Just got a 75' U7N at a fantastic price (i think)... I was checking and found out that 75' U7N use a different panel. is that true?
