Honor Magic V3
eyz
What that
its wifi call. similar to volte, but your call network will switch to using wifi instead of data if you are connect to a wifi network.
V2 CN version dont have, while V2 global has it.
yhw22
How do you enable it? So far, I have never seen these options before. Is it available to most telecom?
DeepseaG1523
Go to mobile network, mobile data, den toggle on Wi-Fi Calling.
Den you will see the VoLTE become VoWifi.
I using StarHub got VoWifi.
Singtel and M1 i dunno have anot.. u can try.
MVNO den dun need think, no such things.
DeepseaG1523
is the CN version able to use vowifi?
CN version not likely to come with our local telco VoWIFI profile.
SG is too small a market for them to even want to waste time to incorporate the profile into CN ROM.
yhw22
For calling preference, set to WiFi preferred?
Btw, what is the benefit of using VoWifi?
DeepseaG1523
If you want ur phone to always prioritized wifi calling den yes toggle that on.
VoWifi ah.. u dun need ur sim card to be on to make or receive calls.
meaning u can be on airplane mode and still receive or make calls.
froztheart
Singtel, Starhub, M1 - MNO all support VOWIFI.
SIMBA likely the only MNO not supporting VOWIFI yet IIRC.
MVNO VOWIFI support is subjective.
pearl_ml
hopefully this v3 global will release soon in SG and by December can see small drop in price.. :LOL:
