Replacing Gaming Laptop with PC
Mclairs83
Been a while since i meddle with PC parts.. after selling off my Legion 5 Pro.. hoping to change back to a gaming rig which probably can last even longer for my gaming needs.
Have scope out the parts below, want to build a white rig with white components.. and didn't know it's i need to pay for the "additional white taxes":eek:
I have bought Crucial T700 for this rig to suit the PCIE5 NVMe and have additional 2TB NVMe from my previous laptop for my games storage.
RAM wise, i'm swinging towards Lexar to suit the memory compatibility list for gigabyte.. any suggestion on the below parts and cheaper places to buy are greatly welcomed.
EDIT (18/08/2024): now to wait for all the parts to arrive (especially for motherboard and ram)
PartsDescriptionPriceLocation
CPUAMD 7800X3d
485​
Techyard
MotherboardAsrock B650 Steel Legend White
278​
Amazon
CoolerPeerless Assassin 120 SE ARGB White
42.49​
Shopee
RAMTEAMGROUP T-Create Expert Overclocking 10L DDR5 32GB Kit (2 x 16GB) 6000MHz (PC5-48000) CL30 Desktop Memory Module Ram White - CTCWD532G6000HC30DC01
144.5​
Amazon
Graphic CardZOTAC RTX 4070 Super Twin Edge White OC
929.99​
Shopee
SSDCrucial T700 2TB NVMe Gen5
244.88​
Amazon
CasingNZXT H5 Flow White RGB
129.51​
Lazada
PSUCM V650 v2 Gold 650w White
107.66​
Lazada
Total
2362.03​
Edited as for 13/08
PartsDescription (White built)PriceLocation
CPUAMD 7800X3d
537​
Bizgram
MotherboardGigabyte B650M Aorus Elite AX ICE
336​
Bizgram
CoolerPeerless Assassin SE 120 White
50?​
Shopee
RAM
945​
Bizgram
151​
Bizgram
PSUNZXT C650 650W GOLD PSU
99​
Bizgram
NightRaven49
CPUAMD 7800X3d
537​
Bizgram
if ur not gonna bundle with the mobo, techyard has this at $475 as tray, which imo is a decent deal since the box doesnt have anything else anyway.
336​
Bizgram
tradepac bundles the b650 aorus elite ax ice (full atx version) with the 78x3d for slightly cheaper than bizgram, based on the price u listed here. might be worth asking how much they sell the mobo on its own, as an matx board in a full atx case leaves quite a bit of space.
CoolerNzxt Kraken 280 RGB - RL-KR280-W1-280 mm AIO CPU Water Cooling - 1.54 Inch LCD Display 240 x 240-2 x 140 mm RGB Core Fans
244​
Bizgram
the nzxt kraken is not a very good cooler, given it performs very poorly on am5 and gets beaten by air coolers that cost a fraction of the price.
personally id get a white peerless assassin for around $50, which is more than enough for a 7800x3d, or if insistent on aio with screen, something like the lian li galahad ii lcd, which costs about the same price from dynacore.
PSUCorsair RM White RM850W
198​
Bizgram
the psu is hidden from sight, so i think getting a regular black psu and white cable extensions (if needed, usually around $20) is a more cost effective solution. the 4070s doesnt require that much power anyway, a good 650w unit like the nzxt c650 gold (also bizgram) for $100 is more than enough.
Mclairs83
Wow. Thanks. really appreciate all the advise given. i will modify according base on your recommendation.
1) Thanks.. will check it out on. maybe the cpu get from techyard then motherboard from shopee/lazada.
2) ah didn't know H5 is a full atx. will change to atx size instead.
3) Wanted to get the peerless assassin, but thought that the heatsink will hit on the ram riser, so drop the idea of having that huge heatsink. will keep that as an option to keep it low. will take other AIO into consideration.
4) thanks. will drop to NZXT psu, can i know where to find those white cable extensions (one bunch)?
kimsix
asrock b650 steel legend if have stocks in simlim, is great am5 board. local prices around $370+ bundled, techdynamic is the distro, you can msg them for stocks :o
amazon.sg may restock, $270, is sold by asrock usa behind, no warranty stocks. :o
https://www.amazon.sg/ASRock-RyzenTM-Processors-Blazing-90-MXBN90-A0UAYZ/dp/B0CXPXBF2M/
Mclairs83
NightRaven49
the ram kit that koenig suggested is fairly low profile at 32mm tall, lower than even corsair vengeance lpx ddr4 (33.5mm). on matx boards and larger, there is enough space between the socket and the ram slots for the heatsink to clear the ram slots entirely. even if the fan gets in the way, u can still shift the fan up a few mm.
for aio id just get the arctic liquid freezer series.
4) will drop to NZXT psu, can i know where to find those white cable extensions (one bunch)?
can find psu extensions on ur online etailers like lazada/shopee.
Mclairs83
Thanks @NightRaven49. Appreciate your help
ragnarok95
Senior Moderator
Senior Moderator
Try to avoid getting extension cable for your PSU. It's better to get pre-sleeved cable that connect directly to your PSU because extension cable might cost voltage drop over time which happen to mine.
NightRaven49
true, then the cm v650 gold v2 white for $120 from dynacore is also viable, same price as nzxt c650 gold with extensions.
50?​
Shopee
id suggest the non se, as the se has exposed heatpipes that may spoil the aesthetic. most places have it for 65.
Mclairs83
Bought the CM V650 gold v2 white at 102 during the offer period. Thanks. for the peerless assassin i already bought it. lol
