Honor Magic V3
Bolivar
Seems like the Magic V3 global variant is only getting 512gb and 12gb ram. It is a shame since the V2 has 16gb ram. Why Honor just can't give international customers the top specs variant.
yhw22
just do a search, since likely 12GB RAM. :mad::(
zobrak
I would rather get the Chinese variant if the global version specs is going to be so thrashy. The Chinese variant V3 has GMS, Android Auto is now available on the V3. Minimal difference to wait for the global version.
can't connect wearos watches and other limitations
yhw22
by default with GMS or need to enable it? as i knew can only enable when put a foreign simcard to enable GMS.
glorygoh
By default have, no need foreign sim card, can even do it over wifi when setting up. need to download playstore frm Honor Appstore, then enable GMS somewhere in Settings.
All china Rom have gms built-in with the exception of Huawei.
DeepseaG1523
i strongly suspect there may be other hardware changes as well.. i might be heading to china to buy china phone though
there will not be any hardware changes, but anyway, just go china buy.
just be wary SG honor will not support provide any form of support or repair as it is a CN set.
yhw22
so mean still need to do some setting to enable GMS. I knew default with GMS but not installed rite?
DeepseaG1523
go malaysia should be ok and cheaper bah.
malaysia set will be same as SG set.
His concern is no 16GB and 1TB version and also he believe there is a difference in hardware lol between CN set and global set.
So he go China buy is the best option.
yhw22
yup. understand. but global set we LL lor. i also feel why drop to 12GB as compared to V2 which is 16GB, at least maintain it mah.
