~sabaisabai~
Me been with them for 20+ years, initially sceptical about MVNO. Now, no turning back!
oh. same here. with them many years
okok I'll port over soon πŸ˜„πŸ˜„
NovelLobster
BRING IT ON!!! Wahahaha…
13 months contract only $91 nia, almost on par with my previous ONE MONTH bill with StarHub!
All thanks to TPG for bringing down the cost πŸ™πŸΌπŸ™πŸΌπŸ™πŸΌ
Your previous 1 month bill is about $91?? Ok means you rich… then you should just top up eight for 2 years lah, only 2 months bill mah…
i was previously with Giga on the $18 plan which was overkill for me since I talk less than 10 mins a month and use only about 35GB a month, so I switched to eight because it’s much cheaper for about the same entitlements as Giga’s $15 plan
HellHunter
Guys, need a bit of advice. I'm currently on Zero1 $7(.07) plan. My bill cycle seems to start on 1st? as my latest invoice states billing period was 1st July to 31st July.
How does porting out work if I plan to switch to Eight in terms of current bill cycle? Should I wait until end of the month to port or will my Zero1 bill be pro-rated based on when I port out?
Any help is greatly appreciated. TIA.
thiamhui
Anyone encountered where line with previous Telco terminated but eight SIM is still on temperory number? No notice of port-in failed either.
Read HWZ Forum Rules on Poco X6 Pro
Just drop them an e-mail with the necessary info. I had the same issue yesterday and was found to be resolved at around 5pm.
And yes, they do reply my e-mail, at around 6 plus.
TyL3r_DuRd3n
What won me over is 8’s ability to answer calls and best of all, the roaming calls is deduct directly from the free IDD mins, no extra money / top-up needed. No brainer lah. It is liberating
eyz
unlikely zero1 will pay you back pro rated.
you can start applying eight and port 1 week before end of the month, or 10 days just to be on the same side.
TyL3r_DuRd3n
Usually MVNO got a period u cannot do porting out, for GOMO and Simba, it is 5 days before end of billing cycle. If you have entered the mentioned period, u can stay on until next billing cycle OR wait until they deduct ur credit card and port out. Not sure about vivifi’s period. Pls do a check. But for $7, aiyah close one eye lah. U have utilized half of it liao as today being August 15th, $3.5 liao
amazingone
Both as my mum's line still yet port over.
Porting my mum's line
wah, not you as well hope you get your enquiry, and mine still not yet replied. send to port in 1st got reply about a few days and say will do it,. and after 1 week still not yet port so i send helpme. 1 week now still nothing has been done....so total of about 3 weeks+ porting still not yet done. probably will be on ourcurrent telcom for maybe another 1 mth + b4 her line can be port over.
Their email replies are on prioritisation I guess, but you can try visiting their service centre for speedier response on port-in.
