Google Pixel 9 series
Which Pixel 9 series devices are you most interested in?
  • Pixel 9
  • Pixel 9 Pro
  • Pixel 9 Pro XL
  • Pixel 9 Pro Fold
  • Other [comment]
artemov
IMO, you should wait for p10 series
P10 is supposedly using a new chip? Most likely people will say wait for P11 or P12 for the kinks to be ironed out.
I'm using P6A now, dunno want to wait or not ...
Loser
Still holding back and thinking if i should upgrade from p8p :unsure:
Haha same, if I change it'll be for the smaller pro.
But p8p resale/trade-in value very bad... Are you intending to sell your p8p to upgrade? What's the best resale value you saw so far?
tak3shi
But p8p resale/trade-in value very bad... Are you intending to sell your p8p to upgrade? What's the best resell value you saw so far?
I'm looking at the 9p XL but only GStore has 128GB
Yes, intending to sell it and unfortunately only iP has high resale value in SG :cautious:.
$800ish~ for 128GB o_O🥲
ragnarok95
Senior Moderator
Senior Moderator
P10 Tensor will be build by TSMC, as compared to Samsung now.
limmk
@limmk korkor, 开工了....
我这次罢工了 :(
crow_nest
https://www.reddit.com/r/Android/s/YfplbEOjvp
Take note, India, Singapore and Malaysia units do not have ltpo on the 9 pros unlike the rest of the world
Dafuq man. We're not even considered ROW too. I wonder what does this mean for battery life in the long run
Edit: as mentioned in the reddit thread. Possible spec list error? Google SG store does list pro and pro XL as super actua LTPO
