[Official]: Changi Mobile
froztheart
Yes there double charges on cc but reflected as 1 on changimobile apps
Communicate with them and they aware there issue, and their billing team try to fix it
Yeah, suggest to write in so that's proof that there's double charges instead of calling for you to track and escalate if necessary.
duhduhduh
Anyone knows how fast they process the port-in? Noted it says it will be completed within 3 business days.
Any one knows the timing they process the port-in?
Spirax
Changi Mobile are the only MVNO that allow Prepaid to Postpaid port-in, using online Myinfo Singpass
froztheart
Leaving it here for those that are looking to convert prepaid to postpaid as 3G shutting down after July.
SINGTEL SIM ONLY STARTER is strictly for prepaid to postpaid ST conversion/GOMO.
Resolved after visiting SIngtel shop and requested for the conversion.
No fees paid as of posting (08th April), and this is the only plan without contract as all other ST SIM ONLY plans have 12 month term.
Also, prepaid to postpaid can be done by Changi Mobile, SIMBA & Circles.Life as far as I have found out, for those looking for other options.
froztheart
Value+
Freedom
Ultimate
Travel
Travel+
Best+ (CIS)
One (One Changi CIS)^
100GB
[50GB 4G + 50GB Stream Speed]
150GB
[100GB 4G + 50GB Stream Speed]
150GB
[Full 4G Speed]
200GB
[Full 4G Speed]
200GB
[Full 4G Speed]
58GB
Unlimited Data^^
$10/mth
$12/mth
$15/mth
$18/mth
$25/mth
$15/mth
$18/mth
300 mins
1000 mins
1000 mins
1000 mins
1000 mins
400 mins
1000 mins
200 SMS
200 SMS
200 SMS
200 SMS
200 SMS
400 SMS
200 SMS
N.A
N.A
Free 1GB roaming data/mth*
Free 3GB roaming data/mth**
Free 3GB roaming data/mth***
N.A
N.A
Free Rollover of Local 4G Data, Talktime & SMS#
Optional Add On - $1 Plan Rollover (Rollover unused Data, Talktime & SMS)#
Free Caller ID
Free Caller ID
Free Caller ID
Free Caller ID
Free Caller ID
Free Caller ID
Free Caller ID
Free Incoming Call
Free Incoming Call
Free Incoming Call
Free Incoming Call
Free Incoming Call
Free Incoming Call
Free Incoming Call
Free Incoming SMS
Free Incoming SMS
Free Incoming SMS
Free Incoming SMS
Free Incoming SMS
Free Incoming SMS
Free Incoming SMS
- As of 21 May 2024
- Each registered Customer can sign up to maximum 6 Postpaid mobile lines with Changi Mobile (maximum 3 Flexi Best+ or Flexi One CIS mobile plan). However, for customer registered using passport, the customer are limited to a maximum of 2 mobile lines.
- Enjoy the convenience of starting your new plan on the NEXT DAY by referring to our comprehensive FAQs on how to Change Plan.
- Customer cannot purchase Plan Rollover Add-on on the last day of his bill cycle.
- To use Data Roaming, Customer with a monthly subscription plan can purchase a Roaming Add-on Bundle, via the Changi Go mobile app. Payment for the Roaming Add-on Bundle is upfront. Alternatively, Customer can purchase our Flexi Travel SIM Plans.
- Customer will also have to enable ‘Roaming Service’ via the Changi Go mobile app. For Flexi Travel SIM Plans, roaming is activated once Customer clicks ‘I have received my Changi Mobile SIM’ in the Changi Go mobile app.
- Changi Mobile currently supports Data Roaming and incoming SMS Roaming services. Incoming SMS received is not chargeable. Voice Roaming and outgoing SMS Roaming services are not supported.
* Applicable for Indonesia, Malaysia & Thailand.
** Applicable for Hong Kong, Indonesia, Malaysia, Taiwan and Thailand.
*** Appliceable for Australia, Bangladesh, Brunei, Cambodia, Hong Kong, Indonesia, Japan, Macau, Malaysia, Saudi Arabia, Taiwan, Thailand, United States and Vietnam.
Applicable only to Airport Staff (One Changi Community Exclusive)
^^ 10GB + Unlimited Data (Streaming Speed) with monthly cap. Changi Mobile Unlimited Data Roaming plans are capped at 150GB.
# If customer is late on payment, all rollover data, talktime and SMS will be cancelled with immediate effect.
froztheart
Data Only Plan for 2nd Devices
50GB @ $20/mth
Unlimited Data
Unlimited Data
Unlimited Data
$35 for 7 Days (Non-CM Subscriber)
$30 for 7 Days (CM Subscriber)
$50 for 7 Days (Non-CM Subscriber)
$45 for 7 Days (CM Subscriber)
$5/Day (Non-CM Subscriber)
$4.30/Day (CM Subscriber)
$7.10/Day (Non-CM Subscriber)
$6.50/Day (CM Subscriber)
Flexible Validity Extension
Changi Mobile Plan Subscription Not Required
Changi Mobile Subscriber Preferential Rate
Includes 1 mth Grace Plan
1GB
30mins Outgoing Calls
5 SMS
FREE Incoming Calls*
Converts to
Flexi Value plan thereafter
1GB
5 SMS
Converts to
1GB
5 SMS
Converts to
- As of 21 May 2024
- You can share your Data Roaming through hotspot.
- You can continue using the Travel SIM while you are back in Singapore as it comes pre-loaded with Free Limited Local Data, Talktime & SMS.
- You should deactivate your Travel SIM after your trip if : (1) You do not wish to use the pre-loaded Free Local Data, Talktime & SMS after your trip and/or (2) You do not wish to use the basic mobile plan subscription in subsequent months. The subscription is chargeable at S$8 Per Month for 12GB, 200 Mins Talktime & 200 SMS.
- Free Local Data, Talktime & SMS are limited to (1GB Data, 30Min Talktime & 5 SMS) and will be valid for a month from the date of Travel SIM activation. It will continue with the basic plan subscription for subsequent months if you choose not to deactivate it.
- If you choose to continue with the basic local mobile plan, you can enjoy our affordable rate for only S$8 per month with 12GB, 200 Mins Talktime & 200 SMS for as long as you want.
- 50GB + Unlimited Data (Streaming Speed) with monthly cap.
- Roaming Network Partners
list.
* Flexi Travel SIM comes with 1 month Grace Plan, At the end of 1 month, your Grace Plan will be auto-converted to a Flexi Value subscription and $8 will be deducted from your payment card.
- You can terminate your line in Changi Go App by clicking on the "Unsubscribe" button displayed under your Grace Plan. To ensure that you will not be charged for Flexi Value subscription, please terminate your line at least 24 hours before your Grace Plan expires.
- Existing CM subscribers, sign up through Changi Go App, under the Add-on section.
jentang
I just ported over to Changi Mobile and received a message that it was successful. Outgoing calls are shown as my Singtel's number but the Singtel sim is still active and can still be used. Anyone knows if this is common? I went to google and it seems like the old card should be deactivated once the port over is successful.
jentang
I think he isn’t referring to Changi but rather his final telco destination which has the no Singtel clause.
Yes, so need to port to Changi which is using M1 then port back to the singtel network telco.
Btw, the singtel sim has been deactivated. Maybe they wanted to earn one more day so they took longer to deactivate.
Cedric7
Singtel hi prepaid can port over to changi mobile postpaid?
