A thread about screwdrivers (seriously?)
quekky
i use some cheapo screwdriver bought 20+ years ago, damn lasting and didnt rust yet. that time only like few dollars
recently got a cheap torque wretch that is varible 2-14NM, for parts that need specific torque
hawthorne
i'm using this...
I was using this, until i need to drill some furniture and my mains powered hammer drill could not fit in the space. So when to hoot this as well
This is powerful enuf to drill wood and to tighten/loosen tight screw, that sometimes the 3.6v FIXA is not able to handle. It cames with torque control so it helps in preventing overtightening of the screws. Its cheaper than the ones with removable batteries sold in hardware shop too.
luei74
Last sat went SLT searching high n low for the Pentalobe P5 screwdriver.....luckily managed to get it at the level 3 :s13:
Godeau
For work, I use a 2 position ratcheting screwdriver
At home, I just use traditional Stanley magnetic tip screwdrivers
cmotif
I use some Wera screwdrivers. A bit of impulse buy :eek:
They have these series of laser etched tip screwdrivers.
Pocoyoz
The ikea set can use to dismantle hdd?
Sent from Amazon using GAGT
cscs3
I'm using this too.... to fix furniture and REAL hardware.
PC hardware, well, I've got plenty of tools bought and gathered over time and there's more at the office lab. Nothing expensive, just ordinary stuff that you can buy from small shops.
Quality not so good. Tip break easily, not for heavy duty.
yuri2
Invest in good tools, spend some money and that screwdriver will last you a long time.
Especially for phillips screwdriver, ph1, ph2.
The good ones are more precise and do less damage to the screws.
Phillips screws are designed to cam out, that means, you're more likely to ruin the screw, and get a stuck one that is difficult to remove.
Then you'll need some special tools to remove damaged screws and waste more time and money.
Wiha, Wera, Vessel are the ones I have.
joesph
black Friday I buy ifixit the most bits
I have Xiaomi electric stick screwdriver
Makita 173 impact driver and 487 driver drill
and some other ÂĽ inch bits bought separately
Read HWZ Forum Rules!
Phen8210
Does anyone remember the specs for GPUs? For the back screws. something to do with 2.5 .. i forgot.
KleoZy
I have been using this for almost 10 or more years now. the bits damn durable as compared to others screw driver kit.
Nanch
