- Jul 29, 2003
can be vivifi just enabled VolteNow I found heya got 5g icon at my iPhone, test around 150mbps. Are they launching the 5g soon?
don't gave ppl false hope.Now I found heya got 5g icon at my iPhone, test around 150mbps. Are they launching the 5g soon?
Since when heya got 5G?Now I found heya got 5g icon at my iPhone, test around 150mbps. Are they launching the 5g soon?
maybe he is using dual sim ... confuse by the volteSince when heya got 5G?
Screenshot your phone and share
Check Facebook for most updated infoAnyone know where has the EZ-Link card for heya?? I like the design leh. I ask their cs they gave me the outdated schedule
It's not updatedCheck Facebook for most updated info
IMHO.It's not updated
Is the APN set to hicard?i just port a max to heya, but my sim card no network..by right it should have network right?
No,it's e-ideasIs the APN set to hicard?
I try zym before and personally quite good. Now going try Heya as it has oversea roaming of 5gb..my zym only 1 gbIs heya good? I am using starhub but the signal at my workplace is shyt. I am considering heya, zero1 and zym. I just need a cheap line to be contactable during working hrs.
Set to hicard. Heya is using hicard and roaming is oso using that APNNo,it's e-ideas
IMHO.Is heya good? I am using starhub but the signal at my workplace is shyt. I am considering heya, zero1 and zym. I just need a cheap line to be contactable during working hrs.
IMHO, The 5g foc on zym is more worth to me Personal usage wise than heya 5gb roam .. zym has 2gb Malaysia roam for $10.10 plan. If you need more the $15 plan have 8gb too.I try zym before and personally quite good. Now going try Heya as it has oversea roaming of 5gb..my zym only 1 gb
wow, it really works! you are better than the store guy and the chat group i am in. ThanksSet to hicard. Heya is using hicard and roaming is oso using that APN
