WuRenJi
top up via the website in $20 blocks. i did receive the successful top up emails.
The last promo, i have to write in to them also. they did the top up after receive my reminder email.
so for those who have yet to receice it, do drop them an email
They probably did it out of goodwill. All along promotion is top up via authorised dealer.
Don't test the system and later cry foul for not giving you.
I received the $10 bonus on aug 14 afternoon.
Valdyr
tbh it sucks, they give me 100GB but I can only use around 5gb cause recep is too unstable
when its 5G it feels like the equivalent of 3.5G on other network
but oh well its cheaps so can't be choosy
Lol, certain speedtests "enthusiast" group admin actually manage to drain finish the 100GB.
Ye_Rongtian
Which plan are you guys on? Is it worth it to upgrade from $10 plan to $12 plan for extra 4gb international roaming or more worth for $13 plan for extra 10gb Malaysia data?
hwsstx
Depends on your usage.
For me Seniors Plan of 1GB Roaming is sufficient for my weekly bus trips to JB. If I were to upgrade to $13, then I would be paying extra of $8 monthly for Roaming that I wouldn't need - $48 extra for 6 months.
Apex
If I want to port my exist Simba line to Zym for instance, when is the best time eg 7 day before next 30 days renewal etc?
Anyone has experience? Can advise?
Thanks.
Recommend 7-10 business days you start the port out in case you hit issue.
avoid weekend and PH.
if everything is smooth usually 3-5 business days settle
username03
Was on $10 for many months. Recently just upgraded to $12.
Usually travel to Malaysia still need to monitor roaming data usage and switch between two simba for 1gb roaming each.. Troublesome..
So might as well upgrade to $12 get 5gb each month no need panic attack.
Ye_Rongtian
So.... the extra $1 for additional 10gb malaysia roaming is not worth it? :s13:
username03
Haha. From $12 to $13 just to get 10gb Malaysia roaming I don't think it's attractive.
If need 10gb means you're there for long period, most likely staying there, which you should have WiFi at the place you're staying..
And also, you could probably get Malaysia sim card cheaper in long run?
manga33
Hi,
Is the Simba plan 5G reliable and smooth. Can it be use underground like MRT....etc. I intend to get it. Thanks.Pls comment for those using it.
