TP-Link EB810v - Quick overview
willy792003
MLO works as I have the client to support it, I'm using Pixel 9PXL, but due to MLO tech still being quite new, the speed is still slower than 1 single 6G band, therefore I'm just using 6G. I will try MLO again and get back to you.
What speed do you get on your P9PXL when connected to 6G? 3+ Gbps?
kashix
I tested on 10gbps network uplink, high end WiFi 7 router, maximum seems to be around 2.1gbps. The same setup, on s24 ultra, I can hit around 3.5gbps. No one had any answer, had to test on myself lol
kashix
Pixel 9 Pro XL
HiHelloBye
just to confirm, s24 ultra <-connected to 6GHz->, you got around 3.5Gbps download? what's the upload speed?
also, what's your firmware version on s24 ultra?
kashix
Should be latest firmware, I got the screenshot, later I upload. Yep I rmb it was around 3.5Gbps on download
kashix
nice, thanks bro
btw, what's your software build number under 'Software Information'?
mine is S928BXXU1AXCA
I have to get back to you on Monday, don't have the info now, phone is with my colleague.
Regardless of software build number, you just need a 5gbps/10gbps internet plan and a high end capable WiFi 7 router to hit this speed. Those 2 requirements more important.
HiHelloBye
yup, already noted on that...
lastly, how's the battery life?
i configured it to stop charging @ 80%, and realised it drains quite fast despite not doing much on the phone...
Nakedtoes
I don't have the same issues you faced, 6G pretty much remains connected, actually all 3 frequencies no problem at all. I'm on latest firmware, so far pretty stable. You want to RMA your set? Could be a hardware problem? I used to dislike TP-Link hardware, but actually really not bad, just that the configuration is a bit too simple coming from my Asus routers.
I got 2 sets actually both set same issue.. Aiyah.. I only trust Asus now.. Tplink big no.
Nakedtoes
6ghz for mine zte z60 ultra..using tplink BE550. Only stable for few days...
DailyRoutine
I have tried EasyMesh with both your models, it works. Ensure that your EasyMesh is enabled on both routers, factory reset your BE230, then find the mesh within the browser, if still cannot find, set your BE230 to EasyMesh satellite mode. If still cannot, set to satellite mode, then connect both by Ethernet cable, paired already, then disconnect the LAN cable. 1 of the method will work, I have tested compatibility for a few models, all works.
Thanks for this!
I factory reset my BE230 and set it to satellite mode. And after adding it as a mesh node, the topology showing in the main dashboard shows the below. Is it configured correctly?
kashix
Thanks for this!
Yes bro, you got it! Hahaha I typed out all the different scenarios I encountered when I was trying it out. Which worked for you?
kashix
I used to have a S24 Ultra awhile back, battery life was very good though.
DailyRoutine
I think the missing step was setting up the BE230 as satellite mode.
once that was done, the EB810v detected a mesh device.
kashix
Network just reset and gone. 6ghz can suddenly gone. Left 5g..if u on MLO worst.. It works for first few hrs.. Then issue arise. I tried think over 8 to 10 firmwares.. None are good. Knn this shows how lousy their support and developers quality. Tplink sucks.. Vowed not to touch this brand forever.
I got it working, MLO all 3 bands! Hahaha
