loganrunning
Has been unblocked and still cannot :(
i received calls, made calls back from jb and hcmc, using the free plan. no changes to number used or config.
in jb, maybe can try connecting to "u mobile", the other roaming partner.
edit: i didn't change the APN, left it at default (ref to faq instructions below). dunno if this makes a difference
roaming faq: https://www.eight.com.sg/roaming
1. Ensure that you’ve enabled Mobile Data and Data Roaming on your mobile.
2. Check if Access Point Network (APN) is set to ‘shwap’
~sabaisabai~
roaming faq:
free idd calls even on free plan??
TyL3r_DuRd3n
yes.
calls in and out, sms only incoming. they do say outgoing sms not supported.
Free plan not supported lah bro for the roaming incoming/outgoing calls, but the $8/$18 supported. :grin:
88GB​
$0/month for 88 days with Promo code: EIGHTNDP2024
(Super Eight Plan)
BUY NOW
  • 88GB Local Data
  • 1GB APAC Roaming
  • 88 Mins Local Talktime
  • 88 Local SMS
188GB​
$8/month
(Double Eight Plan)
388GB​
$18/month
(Triple Eight Plan)
~sabaisabai~
88GB​
(Super Eight Plan)
BUY NOW
  • 88GB Local Data
  • 1GB APAC Roaming
  • 88 Local SMS
188GB​
$8/month
(Double Eight Plan)
388GB​
$18/month
(Triple Eight Plan)
i also saw the $0 plan does not come with free IDD calls
but since @loganrunning mentioned can, so i tot maybe they allowed for free idd calls:p
wulu1_69
Did what you've suggested, call using maxis network kena block and uMobile has no dialing tone and the call cut off by itself :(
~sabaisabai~
something wrong somewhere:(
can you try to turn off and on the mobile, and re try again?
loganrunning
88GB​
(Super Eight Plan)
BUY NOW
  • 88GB Local Data
  • 1GB APAC Roaming
  • 88 Local SMS
188GB​
$8/month
(Double Eight Plan)
388GB​
$18/month
(Triple Eight Plan)
but it worked, so that's what counts :ROFLMAO:
loganrunning
that is very strange, esp on a paid plan. sounds like backend problem.
going from the anecdata here, eight may have backend/provisioning issues. like cannot get otp from eight after porting in, receiving overseas sms etc.
best to escalate - fastest reported escalation seems to be at ubi.
~sabaisabai~
bro, you sounds from telco industry leh.. knowledgeable:D
jsut quite unlucky if cannot receive otp after porting in
