WiFi 7 Device SpeedTest and WiFi 7 adapters
New WiFi 7 speedtest results from Kashix, best results so far in this forum.
Asus ZenWiFi BQ16 WiFi 7 router, Pixel 9 Pro XL WiFi 7 phone.
Speedtest with internal wifi card on wifi 7 with Deco BE85.
https://forums.hardwarezone.com.sg/...and-tuf-be3600.6952409/page-11#post-153549218
Existing USB WiFi adapters do not support WiFi 7.
https://forums.hardwarezone.com.sg/threads/usb-wifi-adapter.7009404
Upcoming USB WiFi 7 adapters.
1) Asus ROG USB-BE92
BE6500 Tri-band WiFi 7 USB adapter, 6GHz band, support 4096-QAM, Multi-link operation (MLO), Compatible with Type A and C, WPA3 network security
https://rog.asus.com/networking/rog-usb-be92/
2) TP-Link Archer TBE400UH
BE6500 Wi-Fi 7 High Gain Wireless USB Adapter
Up to 2880 Mbps (6 GHz) + 2880 Mbps (5 GHz) + 688 Mbps (2.4 GHz).
kashix
Bro you misunderstood. This one is Speedtest with internal wifi card on wifi 7 with Deco BE85.
Pixel 9 Pro XL around only 2.1-2.2Gbps on BQ16/BE85.
Thanks for the correction.
What is the computer configuration (CPU)? Using Intel BE200 WiFi 7 adapter or Qualcomm QCNCM865 adapter?
kashix
COMFAST USB WiFi 7 adapters are reported to be available, may not be compatible with Linux as they are based on RealTek chipset.
1. CF-983BE BE6500
http://www.comfast.com.cn/index.php?m=content&c=index&a=show&catid=13&id=200
2. CF-987BE BE6500
http://www.comfast.com.cn/index.php?m=content&c=index&a=show&catid=13&id=202
Reference: Linux problem with Realtek 8912AU chipset based WiFi 7 adapter
https://github.com/morrownr/USB-WiFi/issues/494
Taobao Comcast Flagship store link at RMB 169 only.
【淘宝】限时官方立减30元 http://e.tb.cn/h.gpIswq5pDPEZ3wH?tk=O7uf3hTVcHO CZ0002 「COMFAST usb无线网卡WiFi7免驱动三频千兆台式机笔记本WiFi接收器发射器6500M大功率电竞网卡 CF-983BE」
点击链接直接打开 或者 淘宝搜索直接打开
Best WiFi 7 speed using Dual Band WiFi 7 router without 6GHz band.
Asus TUF-BE6500 router, Intel BE200 WiFi 7 adapter.
https://forums.hardwarezone.com.sg/...and-tuf-be3600.6952409/page-10#post-153501129
This one is really hard to beat (2202Mbps download, 2357Mbps upload) for dual band WiFi 7 router without 6GHz band,
My test results at close range 0.5m and Intel BE200 adapter.
The following results are with a WiFi 7 capable notebook, Acer Swift Go OLED 2024 model (Core Ultra 125H CPU, 16GB/1TB) with the on-board Intel Killer(TM) Wi-Fi 7 BE1750x 320MHz capable Wireless Network Adapter (BE200NGW)
For good 2x2 160MHz WiFi 7 client, the speed will be at about 1.2Gbps to 2.0 Gbps (MAX PHY Link Speed 2882 Mbps).
1) ZTE BE7200 Pro+ router in AP mode, CH60, 0.5m away
2) Xiaomi BE5000 router in AP mode, CH60, 0.5m away
3) Asus TUF-BE6500 router in AP mode, CH44, 0.5m away
4) TP-Link TL-7DR6560 (BE6500) in AP mode, CH44, 0.5m away.
morimorimori
3m line of sight to EAP-772. iperf3 server on unraid nas.
Windows 11 24H2 preview. Comparison of Wifi6 on 5ghz band and Wifi7 (maybe? see later note) on 6Ghz. Wifi adapter turned off when not under test.
Test 1 Acer swift3 314-57. Built in wifi
Protocol: Wi-Fi 6 (802.11ax)
Security type: WPA3-Personal
Manufacturer: Intel Corporation
Description: Intel(R) Wi-Fi 6 AX201 160MHz
Driver version: 23.60.1.2
Network band (channel): 5 GHz (161)
Aggregated link speed (Receive/Transmit): 1081/1201 (Mbps)
Link-local IPv6 address: ***
IPv4 address: 192.168.11.63
IPv4 default gateway: 192.168.11.1
IPv4 DNS servers: 192.168.11.1 (Unencrypted)
Physical address (MAC): ***
Connecting to host 192.168.11.32, port 5201
[ 5] local 192.168.11.63 port 56324 connected to 192.168.11.32 port 5201
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.01 sec 53.9 MBytes 447 Mbits/sec
[ 5] 1.01-2.00 sec 81.5 MBytes 690 Mbits/sec
[ 5] 2.00-3.02 sec 86.6 MBytes 716 Mbits/sec
[ 5] 3.02-4.01 sec 82.4 MBytes 695 Mbits/sec
[ 5] 4.01-5.01 sec 82.2 MBytes 693 Mbits/sec
[ 5] 5.01-6.00 sec 71.9 MBytes 607 Mbits/sec
[ 5] 6.00-7.00 sec 82.4 MBytes 689 Mbits/sec
[ 5] 7.00-8.01 sec 78.1 MBytes 650 Mbits/sec
[ 5] 8.01-9.01 sec 83.4 MBytes 702 Mbits/sec
[ 5] 9.01-10.01 sec 83.1 MBytes 697 Mbits/sec
[ 5] 0.00-10.01 sec 786 MBytes 658 Mbits/sec sender
[ 5] 0.00-10.03 sec 784 MBytes 655 Mbits/sec receiver
Test 2 Acer swift3 314-57 comfast CF-983BE in USB3 port
Speeds are more inconsistent than yesterday, this was probably the best result. Previous test topped out around 240MBits/s. Can't force it to use wifi7 protocol. First packet always seemed to be very bursty/ fast. Won't do any further testing until 24H2 is properly released. Also don't know whether I want to throw any more money into Wifi7 when the TP-link/ Asus USB come out.
Protocol: Wi-Fi 6 (802.11ax) <----???????
Manufacturer: Realtek Semiconductor Corp.
Description: Realtek 8912AU Wireless LAN WiFi 7 USB NIC
Driver version: 5002.24.117.0
Network band (channel): 6 GHz (69)
Aggregated link speed (Receive/Transmit): 2882/2882 (Mbps)
IPv4 address: 192.168.11.86
[ 5] local 192.168.11.86 port 55140 connected to 192.168.11.32 port 5201
[ 5] 0.00-1.01 sec 85.2 MBytes 709 Mbits/sec
[ 5] 1.01-2.01 sec 97.1 MBytes 816 Mbits/sec
[ 5] 2.01-3.01 sec 94.8 MBytes 795 Mbits/sec
[ 5] 3.01-4.01 sec 98.1 MBytes 824 Mbits/sec
[ 5] 4.01-5.01 sec 13.4 MBytes 111 Mbits/sec
[ 5] 5.01-6.00 sec 0.00 Bytes 0.00 bits/sec
[ 5] 6.00-7.00 sec 62.0 MBytes 518 Mbits/sec
[ 5] 7.00-8.00 sec 48.5 MBytes 406 Mbits/sec
[ 5] 8.00-9.00 sec 45.9 MBytes 385 Mbits/sec
[ 5] 9.00-10.01 sec 37.2 MBytes 311 Mbits/sec
[ 5] 0.00-10.01 sec 582 MBytes 488 Mbits/sec sender
[ 5] 0.00-10.01 sec 580 MBytes 486 Mbits/sec receiver
No issues with Comfast CF-983BE WiFi 7 adapter on my Acer Swift 3 Year 2021 laptop (built-in Intel AX201 WiFi 6 adapter disabled, Intel Core i5-1135G7 CPU, 16G/512GB, Windows 11 23H2, model number SF314-511-53T9).
ZTE BE7200 Pro+ dual band WiFi 7 adapter (no 6GHz band), CH60 on the 5GHz band, 160MHz channel bandwidth.
Very close range (0.5m distance)
Close range (4m distance)
In the previous test, I forgot to open the Antenna. With that the speed increased quite a bit at 4m distance.
No improvements on very close range though (0.5m distance)
Using the Comfast CF-983BE BE6500 USB WiFi 7 adapter with a Ryzen 5 5600G desktop (16GB/1TB) running Windows 11.
ZTE BE7200 Pro+ dual band WiFi 7 router, CH60, 160MHz channel bandwidth.
4m distance (PHY Link Speed 2882Mbps).
iperf3 speed is similar, using -P4.
iperf3 server -- upstream OpenWRT router, 192.168.48.1
iperf3 client -- Acer 2021 laptop connected to ZTE BE7200 Pro+ AP
Download
Bash:
PS C:\work\networking\iperf-3.17.1-win64> .\iperf3.exe -c 192.168.48.1 -R -P4
Connecting to host 192.168.48.1, port 5201
Reverse mode, remote host 192.168.48.1 is sending
[SUM]   0.00-10.02  sec  2.02 GBytes  1.73 Gbits/sec    0             sender
[SUM]   0.00-10.01  sec  2.01 GBytes  1.72 Gbits/sec                  receiver
Upload
Bash:
PS C:\work\networking\iperf-3.17.1-win64> .\iperf3.exe -c 192.168.48.1 -P4
[SUM]   0.00-10.00  sec  1.23 GBytes  1.06 Gbits/sec                  sender
[SUM]   0.00-10.02  sec  1.22 GBytes  1.05 Gbits/sec                  receiver
