Google Pixel 9 series
Which Pixel 9 series devices are you most interested in?
  • Pixel 9
  • Pixel 9 Pro
  • Pixel 9 Pro XL
  • Pixel 9 Pro Fold
  • Other [comment]
Lazyfoolz
i think they mentioned was 14xx after discount, discount is $460
1919 - 460 = do some math & u should know how much it cost.
So far all colors have for 256gb. 512gb only left black. I also ask they say alot of ppl hoot already.
mahcosg
Anyone on circles esim plan experienced not being able to use and receive voice calls?
circles technical team told me pixel doesnt support volte......
TopGun
Decided to go for $1739 less 15% using Google store code. Comes with 599 store credit and 1 yr Gemini AI subscription which I use.
The $599 can go for a pixel watch 3, which comes with its own $149 store credit. Overall a good deal for those who wants the watch.
Else go retail for a straight $200 discount at $12xx
Lazyfoolz
Fyi. 12xx is a very noice price to hoot. Also i ask when they release the pixel 9 pro. They told me Q4 of this year. No confirm answer on the actual date
kashix
I bought 3 from there. I can't rmb the retail price for 512 as all I bought are 256.
kashix
Mix of 4G and Wifi. My plan got no 5G so cannot try. Will get slightly warm sometimes but temperature is on the cooler side if compared to most competitors. Yesterday it get really warm once only under the hot sun, and temperature shows that it is 40°C.
The battery if compared to my P8P with the same usage, the P9PXL is way better. I was surprised how slow the battery drop when I on Power saver, can slowly go home no issue. But too early to say since Pixel battery life quite inconsistent. Shall see if today can last that long not.
Hopefully after 1 week, the adaptive battery can extend the battery life. Then next hope is android 15 HEHEHE.😆
Next time you want say battery very strong, you have to say straight outright that you're using 4G and WiFi to achieve your SOT. If not very misleading uh, now usage is all 5G already.
Lazyfoolz
Hmm have u tried to change some setting on ur sim settings? Maybe sim setting change abit then can use liao?
