loganrunning
Ur solution :s13:
anyway, Ubi boss and i tried all sorts of way to find out the problem.
Checked the settings for blocking incoming international sms.
Terminated my eSim, changed to physical sim, plugged the sim card into his phone. Thinking it was the eSim problem but, that is not the problem.
sent sms from two indo numbers to four different Eight numbers. All cannot receive sms from two different telcos from Indo.
We left no stones unturned and finally he escalated to the back end. He was that passionate and curious to find out simidaiji also.
shared all the details and phone numbers involved in this witch-hunting to eight team. Maybe they need more time coz this is new to them.
Maybe u should suggest another solution, is to jump back to GOMO and forfeit my 15mths of subscriptions and be miserable in EWL tunnels and crowded areas. Outside Singapore cannot receive or make calls :razz:
sounds like something is blocking Indonesia SMS from reaching Eight. I wonder if this is also seen on Starhub numbers too (since Eight is using Starhub infra).
TyL3r_DuRd3n
These are latest email reply I received from them
Dear Customer,
Our technical team is contacting international routing with Telkomsel Indonesia on this one. We will get back to you. Sincere apologies for the delay.
Regards,
Team eight - V
a few days after i lodged the complaint via Ubi boss, they sent me an iMessage, thinking they were sending via SMS. 🤭
Okay. We’ll try to SMS test by SIGOS. Please wait
loganrunning
Dear Customer,
Regards,
Team eight - V
on the imessage, was it green or blue? :ROFLMAO:
shouldn't they tested using SIGOS from the start? (since that is the system that is sending the SMS OTPs)
will hold off drawing inferences on their technical problem solving capabilities, for now ;)
loganrunning
if the imessage message was green (assuming you are on iphone), then it probably was sent as a sms. if you are not using iphone, then it would also be sent as an SMS. Even then, to replicate the problem of not receiving OTPs, they should have sent it from the SIGOS system in the first place.
hope they sort it out soon
SPEED
Eight porting very fast.
Online apply to port in 2x ZYM lines on 02/09
Collected physical SIM on 03/09 lunch time.
and now 04/09 already ported over.
zym lines no more active.
Eight FTW!
Jurong640
WiFi on means that's WiFi speed? But some users mentioned having got 5G in Malaysia, I read...
you get 5g roam too when travelling? I used in jb last time forgot if it has 5g on maxis or true
Yes. I tried roaming in JB and Kluang. I can confirm I got 5G NSA on My Maxis.
Eight sometimes will connect to 5G network randomly for a while, then drop back to 4G.
That happens on my iPhone 13 mini sometimes, but speed wise don't feel much difference.
OH really? I didn't get any switching from 5G to 4G. Or is it probably tapped into malaysia network in woodlands? Cos malaysia can use 5G for eight on My Maxis
amazingone
Eight 5G is quite random, also dependent on location as well.
yukita
I'm Singtel user. basically porting my share line out. i guess I just wait for another day then.
my port in completed. can receive SMS as well. all seems good.
2 sept 7pm - get new card from ubi and request port in my singtel share line immediately. Was told 3-7 days to port in.
3 sept - nothing happen
4 sept 7am - morning wake up already ported successfully.
Edit to add timeline, for benefit of others.
