hermes76
- Mar 22, 2006
I can't even login the app now. Keep getting the session timeout error after entering phone number.No issue with paylah this morning
Even after reinstalling the app?I can't even login the app now. Keep getting the session timeout error after entering phone number.
Yah, really very weird.Even after reinstalling the app?
paylah default scan n pay app on mineHi, any of u guys have issues using Paylah?
I had 2 good transactions last Sat morning. Then after that kept having session timeout error. Re-install n reboot phone also the same.
I have no issues with digibank app, Grabpay, Gpay etc
factory reset if not too much of hassleYah, really very weird.
Yah, last resort. But need prep my spare phone 1stfactory reset if not too much of hassle
Yup. It will be later than India global rom nia. We shld be using US global rom. Not sure abt thisIf we buy the china global rom flashed version, can we update the firmware whenever theres an update?
India always 1st, then normally NA then EU and global. EU and global share device code CPH2581 but is different from, ours are mostly/all flashed to global, not NA or EUYup. It will be later than India global rom nia. We shld be using US global rom. Not sure abt this
Yes, no issues.. Just got one today.If we buy the china global rom flashed version, can we update the firmware whenever theres an update?
How's your experience transiting from op 7 pro to pixel 9 pro xl?if you buy export set, they open a new china set and flash global rom and re-package it to be sold as BNIB. If that's what u mean then no but i assume ppl who is buying it knew about it and willingly took that risk also when they are paying for it. But if u buy from official local oneplus shop i would assume BNIB mean BNIB.
But for the battery is a completely different story, where do you think these ah beng mobile shop get their battery from? OnePlus OEM factory? If you think of it, why would OnePlus even sell battery when they decided to build made all their phone with in-built battery? And when they change the battery for you, did they tell u honestly this battery is reused or tell u it's brand new? I'm pretty alot consumers and boomers wont know, they thought they are changing to a brand new battery with better longevity than their current one. But in reality it could be worst.
White is CN only, meaning no esim no matter whatHello anyone knows is there esim version for the non local set? I wanted the silver color but its CN set so not sure any sellers got the esim version or not.
alot thing not used to it. no double tap to lock, no network meter, can't swap navigation buttonsHow's your experience transiting from op 7 pro to pixel 9 pro xl?
