TP-Link EB810v - Quick overview
JT2008
0.14.0.3.00 v608b.0
Build 240709 Rel 56868n
Included Test Internet speed option
Speed tested in Aginet were between 7600 to 8000 Mbps from 6pm yesterday to 11 am today.
0.14.0.3.00 v608b.0
Nice one. This was one major missing feature compared to HB810 and Archer BE800.
nephilim
I'm still on 0.4.0 3.0.0 v608b.0 Build 240122 Rel.66930n.
Still telling me my firmware is up to date both on AGINet app and web admin. I'm on Starhub.
kimsix
just check for updates, not available for me too. :o
stupig SH, just release jiu release, mybfd
Gforce_Ti
How you managed to get update to the firmware? I try to search for update via app and web. Nothing was prompt for updates.
JT2008
Just click on the firmware update option and then it prompt for update. Nothing special
zzzdidi
firmware not updated
connection frequently drops and i have to restart the router modem every morning or few times a day sibeh sian why did i go sign up for a new plan....
kindredSG
Hmm yeah I don't see any update either - it confirms it is the latest:
Henry Ng
wireless setting no mu-mimo options? can set ap isolation. saw 240mhz DFS but unusable here, keeps falling back to 80mhz. 160mhz DFS works though
what is psc channels??
59% memory usuage seems same as hkepc review, so 2GB? :o
Chrome google speed test can do 6.8gbps download?!
Any security setting in this router?
kimsix
i turn off spi firewall for ipv4 and 6, these lower my upload speedtest :o
SH completed the WO for you? how is eb810v you finding?
and nobody else got OTA firmware update? TS is SH priority tester?
Henry Ng
Still have not as Mger on leave and may be next week then install again. That day tech came but no internet on ONT so went back. Now backend said already provision my port.
tormont
I am thinking of getting two units of EB810v for a 4-Room BTO.
May I know from the current users of this router,
1. Is there intermittent disconnection when using the internet (especially when i do ethernet backhauling)?
2. Is the wifi coverage good?
3. Anyone uses the tel port on EB810v?
Thanks in advance
mac34mac
I setup easymesh with EB810v and BE230. But I notice the Guest WIFI clients only connect to main router (EB810v) and never connect to the satellite node (BE230) even it is very near to BE230 and very far away from EB810v. Does Guest WIFI network work in TP-link easymesh?
Anyone has similar setup and can share the experience? Thanks.
As of now, Guest Network (or IoT Network) does not work with the Easymesh satellite nodes.
TP-Link's EasyMesh is a half baked solution in its current form.
If you want better user experience, go for the more expensive Deco.
Reference: General limitation of the TP-Link EasyMesh
https://www.tp-link.com/sg/support/faq/3529/
Q13. Does TP-Link EasyMesh system support syncing Guest or IoT Network settings across the main router and satellite nodes?
A. Currently, the TP-Link EasyMesh system does not synchronize the Guest network or IoT Network settings across the main router and the connected satellite nodes. The EasyMesh satellite nodes will only sync the main wireless network settings.
We will address this in future updates to improve the overall configuration and management experience of the TP-Link EasyMesh system. Any updates will be communicated through our official channels.
