TP-Link EB810v - Quick overview
sold off my eb810v, bit the bullet and got the be85 deco.
Good move.
Even TP-Link Staff says they can not support EB810v well and ask the user to contact Starhub.
https://community.tp-link.com/en/home/forum/topic/697062
Hi, thanks for posting question on our community.
I can understand your needs, while it is a pity that EB810v is a customized model by some ISPs only in your region. We can know less and do less than common models.
You may feedback to Starhub directly.
At the same time, I'm moving this conversation into the ‘Feature Request (Routers)' area for better visibility. Then other people can vote there is they have same requirements.
mac34mac
As of now, Guest Network (or IoT Network) does not work with the Easymesh satellite nodes.
TP-Link's EasyMesh is a half baked solution in its current form.
If you want better user experience, go for the more expensive Deco.
Reference: General limitation of the TP-Link EasyMesh
https://www.tp-link.com/sg/support/faq/3529/
Q13. Does TP-Link EasyMesh system support syncing Guest or IoT Network settings across the main router and satellite nodes?
A. Currently, the TP-Link EasyMesh system does not synchronize the Guest network or IoT Network settings across the main router and the connected satellite nodes. The EasyMesh satellite nodes will only sync the main wireless network settings.
We will address this in future updates to improve the overall configuration and management experience of the TP-Link EasyMesh system. Any updates will be communicated through our official channels.
Didn't know about this limitation before setting up the easymesh. Hope TP-Link will provide updates in near future.
gavthang
Starhub came today to upgrade and install the EB810v router and AP.... forgot to ask him for the router password to setup my AGINET app... anyone knows the default password they use??? I tried Starhub@123... doesnt work....
Jjxjjjyy
The trooper nv give u? Is written on the green orientation paper too.
goondo
Try
Admin1234!
EastSider
any decent budget mesh to go with EB810V? just need to cover the house , no need gaming , just more coverage for video loading etc..
gavthang
Looks like i would need to reset the router... anyone here resetted the router? easy to setup the mesh wifi with another eb810v?
Please share.
Thanks
kimsix
SH where is the ota update? Cant download ios18 6.9gb on wifi 6e wpa3. Need to connect to wifi 5 guest network…
Jjxjjjyy
firmware not updated
connection frequently drops and i have to restart the router modem every morning or few times a day sibeh sian why did i go sign up for a new plan....
I just got mine installed and also experiencing DCs, on my eg phone 2.4ghz , TV fire stick 6ghz. I mean is not bothering me much as reconnection happens as soon as DC.. but I would imagine if u wfh and do some vpn stuffs the DCs wouldprobably make u re login again and depending on how cumbersome/no. Steps to login to coy VPN this could be a legit biggie issue imagine u on a important online meet and u got DC-ed lol...
mac34mac
After using eb810v, one of the room in my house which is 8m from the router, with 2 walls in between, is getting very weak connection. It is very bad that can't connect to WIFI most of the time. Is it normal for this router?
I did not have this issue on my previous ASUS-AC86U.
It is quite normal that wireless speed drops a lot after two walls. You may just be lucky with your old RT-AC86U (an excellent WiFi 5 router, but now EOLed by Asus).
If you cannot put your main router in a central location, you may well need two nodes of EB810v for typical 3/4 bedroom flat. Starhub anyway recommends two EB810v nodes for flat with 3 to 4 bedrooms.
https://www.starhub.com/personal/broadband/routers.html
Type of router
TP-Link EB810v
Nokia Optical Network Router
WiFi StandardBE / WiFi 7AX / WiFi 6
Max WiFi Combined BandwidthBE22000 Mbps
(Tri-Band)
6000Mbps (Dual Band)
Concurrent Transmission Streams2.4GHz: 4x4 @40Mhz,
1376 Mbps
5GHz: 4x4 @240Mhz, 8640 Mbps
6GHz: 4x4 @320Mhz,
11520 Mbps
2.4GHz: 4x4 @ 40MHz, up to 1200Mbps
5GHz: 4x4 @ 160MHz, up to 4800Mbps
Internet WAN Port10Gbps10Gbps
10Gbps LAN Port11
2.5Gbps LAN Port3-
1Gbps LAN Ports-3
USB Port11
Plan SuitabilityUltraSpeed 10Gbps Broadband planUltraSpeed 5Gbps Broadband plan
Recommended minimum number of units based on housing type
  • 1-2 bedrooms: 1 unit
  • 3-4 bedrooms: 2 units
  • 5 bedrooms: 3 units
  • 1-3 bedrooms: 1 x 10Gbps router
  • 4-5 bedrooms: 1 x 10Gbps router + 1 Smart WiFi router
  • 5 bedrooms and above, landed and multi-storey home: 1 x 10Gbps router + 2 Smart WiFi
mac34mac
Type of router
TP-Link EB810v
(Tri-Band)
1376 Mbps
6GHz: 4x4 @320Mhz,
11520 Mbps
10Gbps LAN Port11
2.5Gbps LAN Port3-
1Gbps LAN Ports-3
USB Port11
I have already setup easymesh with Archer BE230. The satellite node is about 6m and also 2 walls from the room. Still getting very weak connection in that room. Now the person using that room is not happy with my setup. :(
Looks like you have no LAN ports in the rooms and you are using wireless backhaul. TP-Link Archer BE230 is a low end dual band EasyMesh node and it is a poor addition to the EB810v, if you need to use wireless backhaul. But if you have LAN ports in the rooms, then maybe there are better setup using Ethernet Backhaul to suit your needs.
Anyway, since you have already bought the Archer BE230, please post the floor plan (with details of the locations of the ONT, main EB810v and Archer BE230, as well as LAN ports in the rooms if any) to see how to optimize the placement of the main EB810v and the Archer BE230 node.
In general, the mesh node needs to have good connection to the main nodes, two walls in between the main node and the mesh node is a NO-NO. Best is to have line of sight with no walls in between. Depending on the situation, you may be okay with one wall in between the main node and mesh node.
Often people think that it is good to put the wireless mesh node (or repeater) to the room with weak signal, that is usually the worst choice.
More about TP-Link EasyMesh
https://dongknows.com/tp-link-easymesh-wi-fi-system-review/
More about Mesh system in general
https://dongknows.com/mesh-wi-fi-system-explained/
berneo
They told me is default at 1234.
They told me if any issue contact 1633 for 24hrs support service woh.
GxK_Jon
I’m getting a second 810v for my bedroom with a lan port. Can the ONT support the wired backhaul through the lan point at the DBbox?
