[Software Update] iOS 18.7.2 is out!
iosnewbie
In lock screen I replaced the camera button with PayLah!
I was quite disappointed that the lock screen customization is only limited to replacing the bottom 2 icons functionality. Would be better for this we can add another 2 more icons to serve other functions.
duabuiji
updated yesterday. my issues here is the widget page does not always refresh correctly. sometimes it will show up as blank for the Fitness and FindMy widget. Others like Calendar is ok. Remove and re-add the widgets does not solve the issue.
I will have to swipe right then left again for it to show up.
Another one is the re-arranging the control center buttons is a bit buggy, but this is no issue for me since i don't customise is frequently.
Another one is "Game mode" does not always activate.
Hopefully 18.1 solves it.
Apart from the above, the update is welcomed.
anyone also faces same problem with the widget refresh bug? or is it only me?
szeli
I use the precipitation lockscreen widget but it doesn’t seem to show the correct info. switched to something else
kenapa siol
ip14 pro updated to ios18. Batt drained slightly faster. Google around and most result saying the phone is indexing and will probably take a few days for it to settle down, once it settle, batt life should be better.
morkutao
yo bros, is this done via "open app" shortcut?
i'm on 15pm ios18 but doesn't seems to have that option.. any idea..?
edit: found it, got to download the "Shortcut" app by Apple
