Honor Magic V3
zobrak
I had this issue but after an android auto update it stopped. Perhaps try to see if there is an update for AA.
However, AA will sometimes still not be able to connect to my radio app. I have to manually launch the app in the phone then it will play to the car via AA.
go to app info, then launch power settings, allow this app to be launched by another app, run background, run at startup
NeonX
Dunno if should get tg protector and just use phone naked not. Am quite impressed with the phone thus far, not sure if wanna risk naked
winningeleven
  1. Go to "Settings"
  2. Tap "About device" or "About phone"
  3. Tap “Software information”
  4. Tap “Build number” seven times. ...
  5. Enter your pattern, PIN or password to enable the Developer options menu.
  6. The "Developer options" menu will now appear in your Settings menu.
Tried the developer options also still can't seem to work. My screen will turn blank even in charging mode. Not sure what setting that causing that
rchow2008
Still setting mine up. Anyone else’s Google backup not working? Says backed up but can’t find the file on new phone. I needed to use cable to transfer all data in the end. Good job I didn’t trade in my old phone!
Those going naked and with decal, is there any grip. Someone said the naked phone like a bar of soap…it is very slippery!
aw1007
I changed to this type ..thin and have some grips as well...
