Travel Neck Pillow
mummynew
Suspended
I have weak neck and so usually suffer quite a bit if require to travel long distance by flight or road (this is the main reason of I falling sick upon arrival at destination due to migraine caused by neck strain).
My travel neck pillow just arrived (taobao) and so far testing it temporarily and seems OK, but need to use it for hours then I will know whether good or not. (in the past, tested inflatable ones which are useless to me, then expensive memory foam one which was too heavy and took up too much of my precious backpack space).
Saw samples of these in airports' DFS shops and found those too small/soft etc and not worth the price of averaged SGD40+.
Anyone has experience with a good travel neck pillow to recommend?
*My new arrival:
ApeTruelove
*My new arrival:
Muji one not bad
szeli
can help to show me what's a 'folded pillow'?
XcoVar
After so many neck pillows. Now stick to Cabeau. The memory foam is really comfy.
xiao.xin
Digging this thread cause needing to find something as will be flying quite often in my new role.
Online general consensus seems to lean towards memoryfoam with Cabeau or Travelrest, where you all get in SG?
arfness
Cabeau TNE s3 hands down, its epic. currently on special on shopee & planet traveller website.
